Update #2
I manually cleaned the valves. Hesitation is still there although not as abrupt.
Things that have been replaced / cleaned so far.
PCV
Spark plugs
Coil Packs
Intake valves manually cleaned
Not sure what else it could be, maybe just a characteristic of the engine.
I did read on an american forum that the intake running flappy motor (vacuum driven) can get a bit worn and so doesn't turn the flaps as efficiently when the engine gets older.
If anyone has any further advice / comments please respond.
So I decided to buy a $25 dollar LED lit USB camera and see if I could guide it into the manifold through the temperature sensor hole and check for carbon build up.
I havent really seen what bad build up looks like so I have attached the pictures I took (not great quality).
I am thinking my hesitation problem is indeed carbon build up.
Let me know your thoughts.
Hi All,
Just lately I have been experiencing a weird hesitation which is most apparent in first gear, but also in 2nd.
When pulling away I try and gently excelerate but the car seems to hesitate and almost jump when in this rev range.
Anyone else experience this in their Tiguan?
As mentioned above it is a manual 125 TSI - Completely stock.
PCV
Spark plugs
Coil Packs
Hi All,
