Originally posted by krracing
View Post
Winter power
ahhh, so it's forge products in general then.... gotcha - i'll probably stay away from that then, cheerssaved me the hassle
let me know how you go with the S3 intercooler Johan - I (as you are) am very curious! How do you propose lengthening the hoses, if they're too short? There doesn't appear to be any aftermarket hose kits for the Tig, as far as i know at least
thanks mateLast edited by krracing; 20-05-2010, 04:32 PM.
Originally posted by krracing View Postahhh, so it's forge products in general then.... gotcha - i'll probably stay away from that then, cheerssaved me the hassle
thanks mate
You'd have to go the silicone hose/coupler route and trial and error I think.2008 VRS Wagon. Yellow, very yellow!
Forever blowing bubbles.
I'd still buy stuff from them, just not ICs .....Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
Originally posted by clip View PostGood to have some cold moist mornings and evenings back again. I reckon it's got to be good for at least another 10kw, if not more compared to a summer's day. Amazing the difference it makes to the Tig.MY2014 Skoda Octavia Ambition Plus Wagon, DSG, Capuccino, Tech Pack
MY 2010 Skoda Scout Manual Silver -traded
AC is continuously variable, and draws about 5nm at idle and drops to about 1nm on acceleration, even down to zero when accelerating "off boost". I'm convinced there's very little drag from the AC when power is demanded, in my Golf anyway! I confirmed this with Vag Com via the AC unit itself, but sure there is always the belt turning the pulleys and more siginificantly, generator.
I agree an S3 IC or even the mighty APR would be the berries, but IMHO some ducting to seal the stock IC to the front of the car, and a on demand water mist is all most traffic drivers could EVER need, at least that's what I've found with many weeks of trial and error testing. Just the alloy ducting alone in my TDI dropped the IC output down to ambient under normal conditions in summer, whereas prior both Polar and myself were seeing about +5 degrees.
Heatsoak at the lights is any turbo cars greatest enemy in normal everyday driving.
Diesels always suffer in cold weather on startup, given there's no spark plug to heat things up, and glow plugs only happen for a short time. Nature of compression ignition I'm afraid. Any turbo car will feel more spritely in cold weather, but Sharkie is right, only to the ability of the ECU to inject extra fuel - a stock map will be limited. I'd have to say my TDI feels peppy these colder days.
Sorry to butt in on a Tig thread, but this is stuff I love to get into!Last edited by Greg Roles; 22-05-2010, 09:28 AM.2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
Originally posted by Transporter View PostCause you drive normally and standard Tig has plenty of usable power for normal driving. How ever you should notice the small improvement in the fuel economy.
1. Our fuel economy was worse than expected (MFD 7.8 way down, 7.3 way back, being 8.0 and 7.5 real as measured). I would have expected an MFD reading more in the high 6's very low 7's.
2. That I noticed wind noise from our roof bars and roof box far more than normal (and it wasn't excesively windy)
1. could be because we had the roof box on, though I have achieved better fuel economy on similar trips with the roof box on in warmer conditions. It is also possible that the roof box was not aligned with the car as well as it should - I checked, possibly off a bit but not obvious.
I have noticed in other cars that Aerials will whistle when conditions are colder and I have noticed our roof bars are noiser now in colder conditions - I presume from the air being more dense?
I did a search on the net, and contrary to what you might think air density is actually lower when humidity is higher. So hot humid air, is significantly less dense than cold dry air. This is due a law of physics observed by Avogadro, see USATODAY.com for a fuller explanation. Conditions in summer up here are generally hot and humid.
Higher air densities are probably most relevant at high speeds, but its interesting to note that even at around 110klm/hr, a Tig is pushing through 1 tonne of air every 7 seconds, or almost 5 tonnes every klm travelled (av air density is 1.2 kg/m3, and assumign frontal area of 2.2*1.8m). So air density may well affect fuel economy, just as wind direction (head or tail) will. Colder conditions may not equate to better fuel economy, though I dont know the balance b/w upside of higher density air going into engine versus car pushing through higher density air to get anywhere, especially at highway speeds.Tiguan TSI Catalina blue, Manual
Originally posted by jimbomort View PostIts an interesting one - fuel economy in colder conditions. Heavier fuel consumption from cold with the colder conditions, better air intake but also higher density air to push through. On a recent drive to Sydney and back in 'relatively' cold weather I noticed two things.
Higher air densities are probably most relevant at high speeds, but its interesting to note that even at around 110klm/hr, a Tig is pushing through 1 tonne of air every 7 seconds, or almost 5 tonnes every klm travelled (av air density is 1.2 kg/m3, and assumign frontal area of 2.2*1.8m). So air density may well affect fuel economy, just as wind direction (head or tail) will. Colder conditions may not equate to better fuel economy, though I dont know the balance b/w upside of higher density air going into engine versus car pushing through higher density air to get anywhere, especially at highway speeds.www.TheRapidWrench.Melbourne
The convenient, professional and affordable mobile bicycle mechanic that comes to you!
My RS build thread
