Tiguan 147TSI rattle concern
  • #16
    Hmmmm I remember noticing that annoying rattle on our 147 testdrive, however havent experienced any noise which can be called as annoying till date
    • #17
      It is definitely NOT pinging, this has been disproved many times over on Vortex.
      Forever blowing bubbles.
      • #18
        Listened carefully today (1st time in a week I drove it) and I don't have ths rattle ..... lots of wastegate flutter though ....
        Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2018 MY18 Golf 110TSI (150TSI) Trendline manual White2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
        • #19
          Originally posted by AlanTig View Post
          Been reading this thread from the beginning and the noise only seems to make itself heard under acceleration...am I correct?
          In the old days prior to electronic control of the engines systems you could adjust the timing,fuel mixture etc...this noise sounds like old fashioned pre-ignition(pinking),which is not supposed to happen on todays engines as a Knock sensor is fitted to detect it...
          I would suggest getting an old time MECHANIC to have a listen to determine whether this is pre-ignition and if so then approach your VW agents with the info....Its maybe that the MAP is set to lean to keep the emmissions down !!!!!!
          Anyone having the issue after an APR remapp or new wastegate?
          Tig 125 TSI
          Black
          Comfort
          Off Road
          20s on the way
          • #20
            Before and after APR remap, made no difference.
            • #21
              It's a bit strange/concerning that not everyone has it. That could indicate a possible manufacturing issue around tolerance variations of some componentry. Bit like some of the holden 186 red motors coming out with one oversize piston - from new!
              • #22
                I beleive that the sound is coming from the cat. Will get the guys at the service to take a look at the first 1000km checkup.
                R36 Biscay Blue 2008 - Sprint Booster, Supersprint Exhaust. - SOLD
                Tiguan 147 Biscay Blue 2010 - APR Stage 1
                • #23
                  Could the noise be related to piston slap, I heard that the engines run a larger than normal piston to bore clearance and that's also the reason why they use a bit of oil between services. Cheers.
                  • #24
                    The general consensus seems to be a noisy/fluttery wastegate.
