Off road tech when off road
  • Off road tech when off road
    We got off road tech but haven't had the chance to test yet. Does it really make much of a difference to the Tigs ability?
    Anyone else used it?
    Tig 125 TSI
    Black
    Comfort
    Off Road
    20s on the way
    It makes a HUGE difference BUT your real limitations will be your tyres and assuming you're in Ausi the fact that you have a low air-dam at the front (I have the "Track and Field" model with a more chiseled nose).
    Basically the off-road brings a number of things into play.
    It modifies the throttle response so you're less likely to spin a wheel.
    It modifies the ABS to allow some locking up in gravel (in soft going it does pay to have the ESP OFF as well).
    It modifies the electronic diff lock (yes I know it's not a REAL diff lock) and locks you into 50/50 torque split.
    It brings in the hill decent control and the hill takeoff controls (ensures you don't run back) over a preset angle.
    There's other bits and pieces as well but it is a major difference BUT as I say you're limited by your tyres AND it cuts out at 20± kph so it's designed for slow slippery work not hotdogging in the gravel.
    Best thing to do is go into a gravel pit or similar and have a quiet play (preferably by yourself) and you'll then have some idea of its capabilities.
    The system the Tig has is actually the same (different programming) as the Land Rover Freelander II so it's actually far more capable than many people realise.
    Derek
    Alexandra
    2022 R-Line Golf Mk8 in Kings Red Metallic
    Previously 3 Tiguans 2008, 2013, 2017
      Hey marcsamus
      Details on exactly what the offroad tech is capable of are sketchy still unfortunately. I have it, and have used it, and it does make a difference.
      Offroad Mode utilizes ABS, the Haldex, the throttle, and both hill descent and climb features. In total, five ECUs manage this off-road system. Hill climb and descent are only activated when the vehicle is at 15 degrees or more, is travelling less than 40km/h, and the driver is not touching the brakes (in the in the case of descent the driver must not be touching the accelerator either). Throttle response is desesntised to reduce the chances of wheel spin and jerkiness over rough surfaces.
      The Tiguan uses the 4th generation Haldex traction system which you can read up about here (I encourage this as it is very interesting): http://en.wikipedia.org/wiki/Haldex_...eration_-_2007
      It gives a nice account of what makes up the 4th Gen Haldex systems and how it operates. In summary:
      - it has an electronic limited slip diff (eLSD) at the back, not a truely lockable differential.
      - It can transfer 100% of the engine power to the front axle or to the back axle as needed. It's the up to the front/back diff to the eLSD to apportion power to the left and right wheels. Numbers are blurry in my head right now, but I think I recall it can transfer as much as 80% of the engine power to just 1 wheel using this system. By default, from a standing start power is split 50:50 between the front and back wheels until you are on the move when it resorts back to approximately 90% of power to the front wheels (for fuel economy and reduced drivetrain wear). When you have activated offroad mode it "locks" the split at 50:50 between front and back.
      This is also quite an interesting write-up on the Haldex 4 system which was initially exclusively available to Saab who branded it Cross Wheel Drive (XWD):
      http://www.autoblog.com/2007/11/30/s...stem-up-close/
      Tiguan TDI, 6spd Tiptronic Auto
      Black, sunroof, comfort pack, off-road tech, tan leather, park assist & roof bars.
      Avg 7.63L/100km over 189,000kms
        my dealer told me that because i ordered off-road the Tig is 1.5 inches higher than a normal Tiguan, is there any truth to this?
          For what it's worth I believe that the hill-decent switches off at around 20 kph not 40 kph and it does allow you to use the brakes to set your descent speed. This is from experience as I've used this feature a lot on back-country tracks around Central Otago. It is possible that the "non Track and Field" model has different settings but I'd be quite surprised if that is the case.
          My manual states (under 3.2 P 21) that the "downhill driving assistant" is only active under 20 kph and that you use the footbrake to set your speed.
          It's worth noting that Booklet 3.2 Pages 20 and 21 have a good basic description of the functions of the "off-road" mode. That's a 2009 manual with mine so it may be different places in the 2010 model.
          NO unless something has changed VERY recently.
          Derek
          Alexandra
            Fair enough, I am willing to accept I got this wrong. I was trying to write from memory as I didn't have the manual in front of me. Thanks Derek.
              i didn't get the offroad tech - think VW sould bring in the TRack & Field modified FrontEnd as part of .
              THere are the bits I consider should be part An OFFroad package
              1. the front end - not used in OZ - not retro?
              2. Drivetrain reprog It seems that it only using existing hardware ( may be the accelerator control is extra) but would have though the ESC system already had that- AM in the process of study the ERwin?ELSA tech training
              Why can't a "firmware" eCU reprogam be done to retro fit, the switch is already installed - needs labell ( and maybe connnecting-)
              GUY H is already offering a HAldex reprog which gives the 50/50 slpit
              3. TPMS Understand the TPMS system requires hardware , sensor in all wheels + receivers on each wheel arch - not Retro ?
              4. More Aggressive tyres retro
              5 a higher GC suspension Kit retro
              5 A rear fullsize Spare carrier ( I am trying to develope a concept which uses th towbar as it's basis) Needs to weigh less than 100kgs. would also Help the dreaded Luggage capacity issue - REtro
              Ted Hagstrom
              2009 VW Caddy, Whte, TDi, DSG
              2009 Tiguan, silverleaf, 103Tdi ,auto, Comfort pack, leather, fogs, Rns510 with RVC
                Seeing as though the switch is just a $300 option you'll probably find that everything to support "off-road" mode is already in place in the vehicle (except the actual switch and possible wiring harness). I've found the Tig to be pretty capable offroad even without the switch but it would be good if we found a way to add the switch afterwards.
                  Have a look at JJJs work on http://www.mytiguan.com/ he's done all that sort of stuff in the past (he's a South African Tig owner). He did a suspension lift and a rear wheel carrier. To be honest I don't think the Tig is capable enough to be worth all that effort. At the outside I'd be getting some steel rims and off-road tyres (5) and just sit the spare upright inside the hatch (it's been done and it fits just fine). SAves a lot of hassle unless you're going to do a LOT of off-road work.
                  Just my 2 cents though.
                  Derek
                  Alexandra
                    This is what i am thinking.
                    If i plan to do some offroading, i would be getting a full size spare in the boot area and some offroad spec tyres (cooper CS4's etc).
                    In reality, if you are planning on doing all that to the Tig to get it offroad, you might as well get an older "True 4wd" like a landcruiser or jeep etc that is built for offroading aas the Tig will only get you so far.
                    It would probably cost less in the long run as well.
                      According to ELSA the front ends are not interchangeable (if I remember correctly). I'm not sure if this means there is some effect/change to the radiator and other lower front engine bay components in order to lose the chin. I'm sure if you are enterprising enough you'll be able to change it though.
                      On one of the forums (cant remember if it was Vortex, MyTiguan, or TiguanOwnersClub) I remember seeing that someone retrofitted the offroad button. It was a simple case of wiring in the button to dis/engage offroad, and then enabling the offroad funcationality via VAGCOM. Not sure if it's 100% like the factory fitted option, but it'd be damn close as I understand it a lot of the work is done electronically.
                      Guys Haldex Performance Part would do part of the job by letting you lock the torque split, but it wouldn't change the accelerator characteristics or hill assist.
                      Nope. TPMS in the Aus Tig uses the ABS to detect changes in the rotation of the tyres relative to one another... there are no special sesnsors in the wheels. To be honest, the aftermarket in-wheel sensors are a lot more accurate and timely in their warnings and would be a better option. When I get my tyres changed I will be installing an in-wheel wireless TPMS solution.
                      Go over to MyTiguan and see the solutions there already.
                        OMG .... that spare tyre on the boot outside has got to be the worst thing anybody has ever done to a Tiguan .....
                        Thats sacrilege ..... looks absolutely dreadful ..... I'd rather walk than be seen in a Tiguan like that ...
                          Originally posted by Arctra View Post
                          ...I remember seeing that someone retrofitted the offroad button. It was a simple case of wiring in the button to dis/engage offroad, and then enabling the offroad funcationality via VAGCOM...
                          You wouldn't by any chance be able to dig out a link?
                            [QUOTE]
                            Understood - NOT RETRO fiitable
                            Would like to find that info - Dealer just say NOT retrofit
                            YEP understood
                            My understanding is that both the differential speed and pressure monitors were in use in current model. BUT I 've already fitted a Aftermarket TPMS -Am committing the sacriledge/surgery with my Dremel Modifing the "ashtray lid" to integrate it . Anyone know to remove ashtray Storage box would make it easier and would enabe neater wiring to rear of Lighter socket
                            HOPE TO achieve a neater solution - too low and looks difficult to open hatch - need a swing aside
                            Sharkie , only for off road use or when luggage space at a high premium - use a roof box first
                            Ted Hagstrom
                              [QUOTE=Tedhaggie;454529]
                              US market legislates true TPMS only, Tiguans there are fitted with the sensors. The rest of us get the software that monitors rotation to determine a flat tyre.
                              I would dearly like to active this tyre monitoring software, I have no need for the off-road part of it.
                              TDI tiguan in the drive. ParkAssist, comfort, fogs
                              Service every 15,000, new fault code every 7,500km
