I made a thread about mine, I'll dig it up.
Installing Sound System in Tiguan (Audio upgrade)
Hi there this a great install and clever way to conceal the amps in the spare wheel well. Can you tell me how the amps are hooked up to the stereo? Did you use line outs for the front speakers and sub?
Also what size speakers are fitted in the front and rear doors of the Tiguan?2011 Candy White Tiguan R Line 170 TDI DSG | Pan roof | Park assist & RVC | RNS 510 | MDI | LED's | 20" RS5 Wheels| Bi-xenons & AFS | Front & Rear footwell lights | Door warning & puddle lights | Mirror puddle lights | LED Tail lamps | Eibach Pro-Kit Springs
Originally posted by Naresh View PostHi there this a great install and clever way to conceal the amps in the spare wheel well. Can you tell me how the amps are hooked up to the stereo? Did you use line outs for the front speakers and sub?
I didn't do the install so I don't know much about that, FHRX Studios did it in Caringbah.Black Tiguan 147 - Sat Nav - Leather - Sunroof - Aftermarket audio - Diamond Audio splits + 12" sub/Audison Bitone processor/Arc Audio amps
Originally posted by suparockin View PostI didn't do the install so I don't know much about that, FHRX Studios did it in Caringbah.
I am still trying to figure out ways to get a clean output signal off RCD310, which does not have RCA out as far as I know.MY12 Tiguan 132TSI + DSG
Originally posted by z1000 View PostI am still trying to figure out ways to get a clean output signal off RCD310, which does not have RCA out as far as I know.
Thanks for the tip on line out converter. Unfortunately sub is out of equation as RCD310 unit clips all freqencies below 80Hz, plus reducing the boot space wont go well with the other half.
The thinking is to tap into the front speakers to amp new component speakers, then tap into rear speakers, filter out high and mid frequency, and amp the rear woofers only.
Wondering what the max speaker depth for front and rear would be though.MY12 Tiguan 132TSI + DSG
Originally posted by z1000 View PostUnfortunately sub is out of equation as RCD310 unit clips all freqencies below 80Hz, plus reducing the boot space wont go well with the other half. Wondering what the max speaker depth for front and rear would be though.
I had a sub in the boot of the Tig, but went with one of these in the Passat:
I had to go the Pioneer as it was the only one that would fit, but I am incredibly impressed with it - as were the installers, they were amazed at how good it sounded. In the Tig with more room, you could go the Focul unit which you can get in 8" or 10":
You could actually go two - one under each front seat. I was going to do that with the Passat, but have to relocate the bluetooth module under the drivers seat first.
Hi suparockin,
That looks fantastic. I hope it sounds as good as it looks.
My ambitions are slightly simpler to start with.
Is there already a sub woofer in a base spec 118 TSI?
Is there an easy audio feed in the rear if I fit my own amp and box sub?
Can I just split off from a rear door speaker feed and if so where's the easiest point to tap into it?
Does the head unit have a line out for a sub?
What's the easist route to run cables front to back?
Where's the easist point to get a power cable through the firewall?
If there's already a thread on the subject please point me at it.
The only audio threads I could find seem to focus on changing the head unit.
Thanks for any help.Tiguan MY12 118TSI, white, no frills..... Had ANS810 ... Note the HAD ..... Now got RCD510 supplemented by 7" Android TomTom mounted on a HoldMyPhone .... Upgraded speakers Vibe BlackAir front splits and MBQuartz 12" ported sub driven from Infinity Reference 5350a amp .... oh and added fun
Originally posted by ido09s View PostI know this is a real old thread but i cant wait to speak to Marty about my Tiguan's stereo upgrades. He is easily the best in the businessBlack Tiguan 147 - Sat Nav - Leather - Sunroof - Aftermarket audio - Diamond Audio splits + 12" sub/Audison Bitone processor/Arc Audio amps
I'd also like to know where to route a power cable from the battery and through the firewall into the car for my amps.
I've just ordered an Audiocontrol LCQ-1 to take the feeds for front & rear speakers, and it also routes a bass only signal for a subwoofer. I'm going to use an active Vibe 12 inch with a fastplug connector so it can be removed easily. Personally I'm not too keen on the flat design subwoofers shown above.2011 Candy White Tiguan R Line 170 TDI DSG | Pan roof | Park assist & RVC | RNS 510 | MDI | LED's | 20" RS5 Wheels| Bi-xenons & AFS | Front & Rear footwell lights | Door warning & puddle lights | Mirror puddle lights | LED Tail lamps | Eibach Pro-Kit Springs
Originally posted by Naresh View PostI'd also like to know where to route a power cable from the battery and through the firewall into the car for my amps.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
