Something In The AC Has Lot Its Mind
  • Something In The AC Has Lot Its Mind
    Hi all,
    Has anyone heard of AC vent controls going haywire?
    Buzzing, flicking, ticking MANY times a second under/in the dash... Like a relay endlessly trying to do something, but failing (wild guess).
    The only other AC related issue, might be connected... AC does nothing, and occasionally throws a fault on OCD for last 5+ years. IIRC, back then, I could only get AC working if I did things manually, not auto/climate control.
    Car is kinda damp/smelly. Windows always fog. Tools in the boot always rusting.
    I'll try upload a video to youtube
    A bad blend door motor will most likely cause the noise you mentioned; when the position sensors fail on them, they will open and close on repeat.
    You can use a scan tool to work out what motor has failed and then replace it based on the erWin guide or a similar online guide like here Volkswagen Tiguan Service and Repair Manual - Adjustment Motors - Air Conditioning
      Has it got a sunroof and if so have you ever cleaned the drainpipes and removed the spider traps
        Thanks for the comments.
        Sorry for not replying, personal issues.
        No sunroof.
        I reckon it sounds like that blend motor thing. Surprised it hasn't burnt itself out, or tripped a fuse etc.
        My mechanic gave me his legit scantool to play with, while sitting in his driveway. All I could find was intermittent AC code showing. Gave no real info, and after resetting, it didn't return while there. Not sure if/when it does.
        Thanks for the link, I'll read-up
          It will almost certainly be the blend door motor/actuator. I just replaced one on my brothers car (Skoda) a few weeks ago. The housings fall apart and then the little gears start slipping and stripping and make that horrible noise.
          Dont buy a cheap Chinese ebay or Aliexpress version as they just dont last. Get a genuine VW one.
            Dreading the job, but really appreciate the solid info, thanks!
