G-8VXWWTRHPN Catch Can - VWWatercooled Australia
Catch Can
  • Catch Can
    Hi, I was after a oil catch can for my Tiguan TSI 4motion Petrol. Anyone applied one to their Tiguan?
    Regards
    MY10 Tiguan 125TSI /APR Stage 2
    For Petrol? Didnt know it needed one.
      Yes they do. PCV valve.
        I have a FORGE catch can on my 1.8tsi EA888. It's great. Look on AliExpress for a kit. ~$150 delivered.
          Is that the one with a Africa plate? I was told it’s only good if you take it to the track, not needed for everyday driving?
            I looked into this. The VW motors are well known for getting gunk in the inlet manifold/throttle body restricting the airflow from the oil vapour coming back through the EGR. A catch can is an (Expensive) solution for this (too late for my elderly Tiguan), or a (cheap) blanking plate (also available on EBay). You will get blank stares if you ask the dealer/specialist about it, as it is illegal as it disables some of the anti pollution system. There is a foam you can spray in which absorbs some of this, sets and is blown out as particles.
            TDI tiguan in the drive. ParkAssist, comfort, fogs
            Service every 15,000, new fault code every 7,500km
              I’ve used the Seafoam treatment in my manifold before. Makes a big difference once it comes out from the exhaust. Once I get the carbon build up cleaned I will invest in a catch can. I looking @ the Forge Motorsport catchcan which connects to existing pcv value.
                A fair bit of info on catch cans in the diesel forum, some recent info here: Catch Can Suggestions
                  Yes, with the plate that replaces the factory PCV.
                  I don't quite see how you could do the job properly without the Afrika plate.
                  Everyday driving, I empty about 300ml of oily gunk every 2nd fuel fill. Ideally, you'd have a ball valve on the bottom of the catch can with a tube attached so that you could empty it every week.
                  Mine cost me about $250 (before I saw them on Aliexpress). That's not a lot of money. I don't think it's ever too late to fit one.
                  The chemical clean is helpful but no substitute for removing the manifold and mechanically cleaning the inlets. I've done both over the years.
                  I'm not aware of any blanking plate for the TSI, so I assume you have a diesel. Diesels need a much better catch can than the TSIs.
                    I have a petrol Tig. Link to catch can:
                    Forge Motorsport Oil Catch Tank Kit for Mk6 Golf GTI | V-tech Australia | Engineered Performance
                      What’s wrong with MAN PROVENT200 ?
                      It’s cheaper and it works.
                      Performance Tunes from $850
                      Wrecking RS OCTAVIA 2 Link
                        Don’t have a diesel.
                          Catch Can
                          Has anyone successfully fitted a catchcan to a MK7 Golf TDI?
                          Also i am looking at fitting the Racingline catchcan to the golf R when it gets here, any feedback on one of these?
                          Sent from my iPhone
                          2014 VW Golf TDI Highline DSG - Limestone Green, DAP, Xenons
                          2018 VW Golf R Hatch DSG - White Silver, DAP , Dynaudio
                          2016 Skoda Superb 140TDI - Family Members
                          2013 VW Amarok TDI420 Highline Auto - Family Members
                            Personally, I'd save $350 and get the unit from AliExpress and fit a ball valve to the bottom...
                              OLd thread I know but do you have a link to the ALIEXPRESS one as Ive looked nad its a mess to find one at that price
                              TIA
