Originally posted by fatjoez
View Post
Mk2 Tiguan VCDS Tweaks
This is a sticky topic.
Originally posted by Hillbilly View PostTook me two goes but was my fault for not implicitly following the instructions Maybe you as well?
Btw bro did you see the comments on page approximately 75/76 of this thread saying DLA requires parameters to function correctly without lag?
Did you enter any parameters?
Sent from my SM-G970U1 using Tapatalk
Originally posted by NZ_GolfR View PostHere are the exact details for the changes using OBDeleven:
Control unit: 09 Central Electrics - Adaptions - Int. light, 2nd generation - Instrumententafelbeleuchtung mehrfarbig - Set to Active
Control unit: 09 Central Electrics - Adaptions - Interior light, light configuration - Ambient_Farbliste_HMI - Set to Active
Control unit: 09 Central Electrics - Adaptions - Ambientelicht Farbliste - Set your RGB Values for all 10 Colour options (Rotwert = Red, Gruenwert - Green, Blauwert = Blue)
Once you have applied the codings reset the Infotainment unit (hold power button down until system reboots) then go into Car - Settings - Background Lighting and you can switch from Brightness Setting to Colour Setting. Change the colour here changes it in the Discover Head Unit as well as the AID.
Originally posted by Marcii1990 View Postcan some one tell me how i enable the background light with vcds in head unit2021 Kamiq LE 110 , Moon White, BV cameras F & B
Originally posted by Hillbilly View PostCant hardly notice it anyway as only lines and dots show. Ive got 30 ambiente colours and its just fluff as I havent changed it from the one I originally put it on
Mine is 2017 and in vcds only had 10 options farbliste in coding.
Is there an unlock for 30 or is it just car dependent.
Ive seen passat have 30
Sent from my Mi 9 SE using Tapatalk
Hi everyone. I just installed the autohold button in my NAR 2018 SEL Tig. Coded it with VCDS and its working as expected, except for the fact that the car turns on when I release the brake pedal (start stop). Does anyone know how to code it so that it will only start up when I step on the gas pedal and NOT as I release the brake? (My EU 15 MK7 golf worked like this).
Thanks!
Originally posted by lgtmelo View Post[FONT="]Hi everyone. I just installed the autohold button in my NAR 2018 SEL Tig. Coded it with VCDS and its working as expected, except for the fact that the car turns on when I release the brake pedal (start stop). Does anyone know how to code it so that it will only start up when I step on the gas pedal and NOT as I release the brake? (My EU 15 MK7 golf worked like this).[/FONT]
Thanks!2021 Kamiq LE 110 , Moon White, BV cameras F & B
Originally posted by Hillbilly View PostWOW at long last someone likes it Must be the only one in the world LOL
I’ve just re-enabled Stop/Start and am considering reinstating the ‘convenience consumers’ and ‘think blue trainer’. LolTiguan Highline 162TSI | Indium Grey | DAP | MY18
Originally posted by spacemannz View PostHave you seen the fuel prices lately?
I’ve just re-enabled Stop/Start and am considering reinstating the ‘convenience consumers’ and ‘think blue trainer’. Lol2021 Kamiq LE 110 , Moon White, BV cameras F & B
