Pass on Dashboard slid down windscreen. What's the best way to retrieve it ?
  • Pass on Dashboard slid down windscreen. What's the best way to retrieve it ?
    I had a pass on my Dashboard and when I turned a corner, it slide just past the centre towards the steering wheel and slide down the Windscreen
    WTF !!! Why isn't the gap between the Dashboard and Windscreen sealed
    Can anyone provide assistance on the best way to retrieve it ?
    I've seen dealer retrieve them using a thin piece of cardboard
    Tig 162 R-Line; Audi TT
      You can buy a rubber strip on Ali Express to fill that gap in for about $5 Bit late now and reason why not to put stuff on a slippery dashboard. Get a bit of wire and the end and sharpen it and try to use that probably need a mirror as well to see it.
        I can't see the Pass anymore. Appears to have slide down. Even taking photos I can't see anything
        Does the gap between the glass and dashboard go to the Engine Bay ?
        I stuck my hand up behind the gap under the steering wheel and I could not feel the pass (looks sealed under the Dash)
          Try a vacuum cleaner with a narrow end on it easy to make one up and tape it on end of pipe
            I have a Vac with a narrow nozzle on the end. Will try that tomorrow.
              Tried with a VAC with a thin nozzle and no luck
              Does the gap between the glass & dashboard go to the Engine Bay OR the the inside of the car (i.e. under steering wheel / under glove box)?
                Logically it will be inside the cabin or would be bloody draughty if was open to the engine bay, wouldn't it. Its on the cabin side of the firewall
                  Thanks mate, thought as much.
                  Can you get to behind the Dashboard (gap between Dashboard and Windscreen) from with under the Steering Wheel cavity OR if I drop down the Glove Box door?
                    get some sticky tape and tape it to the end of thin rigid cardboard. Slide it down the gap and go fishing.
                      Thanks mate, will try that
                        Mission accomplished. Super thin wire with tacky end.
                            Is this what you were referring to?
                            165cm Car Dashboard Soundproofing Sealing Strips For VW Rline TIGUAN PASSAT B7 B8 CC JETTA GOLF 7 MK7 GTI POLO Accessories| | - AliExpress
                            Has anyone bought this and if so how does the final install look?
                              Yes Ive got it and you cant see it once its installed Just a tip fit it in from one end and push it towards that end as you fit it and when you get to other end cut it half an inch longer and push it in as it will shrink an bit over time. DONT trim it to length before you fit it
