Just recently noticed strong smell of hot oil/transmission fluid from the engine bay after a run. Cannot see any evidence of leak of any kind anywhere. 2020 comfort line, 3000 K's. Any advice before I ring VW? Cheers
Oil/ fluid smell from engine bay
Originally posted by Peter A View PostJust recently noticed strong smell of hot oil/transmission fluid from the engine bay after a run. Cannot see any evidence of leak of any kind anywhere. 2020 comfort line, 3000 K's. Any advice before I ring VW? Cheers2021 Kamiq LE 110 , Moon White, BV cameras F & B
Hi Peter
Smeling on burning oil is not normal. Smell of new hot run in components is bit different .I would advise you go under the car , remove engine bay plastic protector , take good lights and check all under . Especially right driveshaft which connect to bevel box ,( gear box) there is on end blue cap which has seals to prevent oil leak . Not many people know but this is common issue on Tiguan to leak there bevel box oil both side ! , and by rotating connected drive shafts it can spray around bit oil, and over this blue cap on top is hot down pipe and catalytic converter which attach on turbo . if oil spray over it smell on burned oil or smoke , hard to detect from top unless you go and check in from bottom with good lighting
I bought an undertray on AliExpress that goes right back to the cross member and covers everything. It has little doors in it to allow for oil changes etc and is 10mm thick very solid hard plastic type material.
Mine still makes the garage smell hot when I close it up after I come home but it soon goes away and is just the normal smell of a hot car cooling off and I wondered but on checking found nothing wrong2021 Kamiq LE 110 , Moon White, BV cameras F & B
