Boot closing issue
  • Boot closing issue
    Hey Guys,
    2019 tig with automatic closing boot.
    Sometimes when the boot closes it closes but then releases so it doesn’t close properly. there is a slight gap so you can see it hasn’t latched but it doesn’t happen all the time
    I’ve moved the boot liner checked for anything that causing it. Any thoughts before it goes to VW?
    Thanks
    Chris
    I found late model Tigs have load sensitive motors. If there is resistance it will reopen about 10cm. 2017 Tiguan used to have pressure pads on the left and right side of the latch in case there was obstruction. My 2019 model doesnt have those.
    so back to your question. If the hatch meets obstruction it will reverse closing and open a short distance after meeting resistance. You may also have an issue with the latch not closing hence the hatch reopens. You should hear the latch attempting to close. What happens if you gently help the hatch to close?
      The boot closes I hear it trying to latch, then it opens slightly. If I press the boot it closes no issue
        check if all the rubbers around the hatch are in place. failing that I think VW service?
          Check your boot floor has not moved back and stopping door from closing.
          Take it out and see if it makes a difference
            double checked all that ive even banged all the plastic surrounds to make sure none are catching
              The it the dealer - warranty claim
              2018 Allspace 162TSI R Line
