2018 Tiguan Allspace Comfortline 110TDI
As of yesterday, when the switch is pressed to open the tailgate, either on the door, inside the car or on the remote, the tailgate opens about 10-20cm and then stops. Each subsequent press, opens the tailgate a further 10-20 cm's. After 8-10 presses, it is fully open and the closing buttons do not work. The closing buttons do not work throughout any stage of this opening process.
Tailgate can be closed through forcing it down manually. Then once in the closed position, pressing the switch seems to lock it in place. Sometimes giving off 3-5 long beeps in the process.
Has anyone else had an issue like this before?
Does the tailgate have a collision sensor somewhere on it? It almost seems like it's stopping due to collision or something like that. But doesn't explain why you then cant close it also.
I'll most likely need to take it in for a warranty assessment, but wanted to see if anyone had any suggestions on here before i did that, or if i'm missing anything simple here.
Thanks!
Thanks!
