mie does the same light dance as in your video. I have seen phonebooth's instructions though haven't yet had time to see if I can code it in.
my journey to activating DLA on a MY17 Tiguan
Originally posted by mr gee View Postmie does the same light dance as in your video. I have seen phonebooth's instructions though haven't yet had time to see if I can code it in.2021 Kamiq LE 110 , Moon White, BV cameras F & B
Originally posted by MickyD View PostMassive kudos to Phonebooth for that detailed post, perfectly easy to follow and activated on mine. I had tried previously and failed, but your instructions worked. I did have an error about the dynamic cornering lights, but it went away by itself.
Originally posted by mr gee View PostMine's a SWB and did some coding this morning and now have DLA ticked in the setup menu on the Discover Pro. Where can I find menu 4B though
[ATTACH=CONFIG]47081[/ATTACH]Last edited by phonebooth; 25-08-2019, 07:33 PM.MY19.5 Tiguan Highline with R-Line & Sound/Vision
Originally posted by phonebooth View PostHere are the instructions I've sent to other users to get DLA working on a '19 Tiguan Highline. Credit to AS Coding @ www.ascoding.ch as my instructions are based on his/hers but with the required changes for the '19 Highline.
Sorry it's so long but I've documented each step I took in detail. Here we go...
Module 09 - Central Electrics
1. Connect OBD Eleven to your car.
2. Turn the ignition on, not the engine! These changes won't apply if the engine is on. I've tried it.
3. Go to central electrics module 09.
4. Select adaptions from the list.
5. Find "Fernlicht_Assistent" and go into that menu.
6. Change "Erweiterte Fernlichtsteuerung" to AFS FLA Fernlicht (GLW:MDF).
7. Change "Menusteuerung Fernlichtassistent" to present.
8. Change "Menusteuerung Fernlichtassistent Worksteinstellung" to present.
9. Save your adaptions using the green tick.
Module A5 - Front Sensor
1. Got to module A5 - Front Sensor.
2. From the list select "long coding".
3. At the top of the page click the little 0|1 to go into Byte/Bit format.
4. Find byte 19. Change it to hex value 30. You can change the hex values by tapping on the hex value in the app.
5. Find byte 21. Change it to hex value 40.
6. Save your coding using the green tick.
Module 4B - Multifunction Module
1. Go to module 4B.
2. In the list, select long coding.
4. Go to byte 9. Change the hex value to 10.
5. Go into byte 10. Tap the checkbox on bit 6 to enable it. Make sure bit 5 is unticked.
6. Go to byte 11. Tap the checkbox on bit 2 to enable it.
7. Use the green tick to save your adaptions.
BEFORE YOU GO ANY FURTHER...
1. Soft reset your head unit by holding the power button until the head unit powers down then powers back on. You can stop holding the power button when you see the VW logo appear.
2. On the head unit go to Menu > Vehicle > Factory Defaults > Lights
Running headlight basic settings
1. Go to module 4B.
2. From the list, select faults.
3. You will see a fault saying "No headlight basic setting" or similar.
4. Down the bottom of your phone screen you'll see a red circle with a trash can. Tap on hold on it. This will try to clear the fault. On mine, the fault didn't clear but this seems to be a mandatory step.
5. Get out of your car and ensure it's on level ground.
6. Go back to the module 4B main menu.
7. In the list of options go to "basic settings"
8. You'll get another list with some settings you can run.
9. Tap "Headlight basic settings".
10. Tap and hold the green tick at the bottom of your screen. You'll notice the headlights pivot out a tiny bit.
11. Go back to the basic settings menu. Select "acknowledge headlight basic settings" (or similar).
12. Tap and hold the green tick at the bottom of your screen. The headlights will pivot back to a "normal" position.
13. Go back to the module 4B main screen and go back into faults.
14. The headlight basic settings fault is still there. This is the moment of truth. Tap and hold the red circle again. Your headlights should dance and the fault should clear.
Go back into the car and run your head unit reset and light factory default again just for good measure. Turn the ignition off, then back on. You should be fault free and enjoying DLA!
Sent from my iPhone using TapatalkMY19.5 Tiguan 162TSI,Pure White,R-Line,Sunroof,DAP
Originally posted by phonebooth View PostHi,
I replied to your PM.
The security code for module 09 is 31347
Thanks to everyone for the awesome instructions and the posts on the forum. I coded it today, and all seemed to go well - just looking for some night driving to see how it works. I have had DLA in my GTI, and i reckon it works really well - so it will be interested to compare.2019 MY19.5 Highline (R-Line, S&V, Sunroof)
Stage 3 - Etuners Motorsport - 228wkW, TCU Tune
G Revision IHI IS38, BMS Panel Filter, CTS Turbo Elbow, CTS Downpipe, Dogbone Insert
Dynamic Light Assist (OBD11), Eibach Pro Kit Suspension
1. Go to module 4B.
1. Go to module 4B.
so i've done all those steps, and everything went as expected per your write-up, but now there's no headlight symbol with the 'A' in it, and if i turn on my highbeam manually, i get an error popping up saying 'error Light Assist'.
Has anyone else come across this?
You have obviously done something wrong then because it definitely works Did you push the lever past normal away from you
Go over it again slowly and carefully including the bit you do outside the car.
Just a thought Have you got the correct headlights2021 Kamiq LE 110 , Moon White, BV cameras F & B
Has anyone else coded DLA whilst HBA was activated?
