The DSG transmission is basically a twin shaft manual gearbox with two independent clutches and should be driven similar to a conventional manual transmission.
Is it advisable or required to shift to neutral in heavy stop go traffic with long waits as you would in a manual car to minimise clutch wear or is the transmission smart enough to disengage clutch when stationary.
Any thoughts on the subject or tips for driving a DSG transmission would be appreciated as this is my first experience with this type of gearbox.
Is the seven speed a wet or dry clutch.
