I'll fiddle with the haldex adaptation and set it to Quiet, see how that goes and update you Tigger73.
Rear Tyres Scrubbing/Haldex Engaging in First Gear
Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
www.nhbautomotive.com.au
OK booked an appointment with the dealer the other day and went back in today. Took the car for a drive with one of the master techs and he agreed with my observations that the haldex is locking up the rear wheels at low speed. He checked the wear on the rear tyres and said to keep an eye on the rear tyre wear at first service. If it's excessive then they may look at taking it further at that time.
He did make note of it on my file so at least it's logged with VW if it ever raises it's head down the track. Probably not a lot more I can do right now unless tyre wear seems excessive or something in the transmission breaks... however given the number of cars out there with similar programming I expect if it was causing major mechanical issues we'd have heard about it for now.
I still don't think it's fantastic but perhaps it just a compromise in terms of traction off the line and tyre wear at low speeds. I'll just put it down as a characteristic of the vehicle and how the factory has decided to set this up in terms of Haldex engagement.Last edited by tigger73; 24-10-2018, 08:18 PM.
Yes I did some similar logging too.
What I was trying to see was the left and right wheel speeds from stationary (1st gear) when turning. The outside wheel should track a larger arc and therefore run at a higher speed.
What I suspect is happening is that the rear wheels are running at the same speed (locked) in first gear. Unfortunately my VCDS is not able to scan fast enough to prove/disprove this but if you can log see both speeds and the Haldex current you’ll hopefully be able to see what I suspect is happening.
My diesel Allspace has the same strange noise and feeling at low revs, medium engine load, up to about 40kph. After that it gets drowned out by engine noise.
The loan Petrol Tiguan I have, has it worse, with the accompanying tire scrub and at any speed(coz the engine is quieter. I can play it as an instrument with the throttle. Most noticeable in the 1400-1900rpm range. All gears and speeds.
Bad impression, that’s for sure. For me and my passengers. It sounds terrible and is not good for the driveline, having it binding up like that.
Not sure we're talking about exactly the same thing. This is really only a low speed (1st gear) cornering issue. It's usually only under 20km/hr when you have a fair amount of lock on the front wheels that it's noticeable. Turning left around a corner from a T junction for example.
I also get a fair amount of front tyre scrub on full lock doing U turns but that's a separate issue.
FWIW, I had a SQ5 for a week.
The Haldex engages much earlier and much more aggressive than the Tiguan when there's any form of steering angle detected.
I wouldn't be too concerned to be honest, another option is to set the adaptation for the Haldex to Quiet
Doing a full lock u-turn in a SQ5 is interesting, it nearly wants to skip/hop like a car with a 2 way mechanical rear diffDaily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
Perhaps it’s the new gen Haldex unit and how it operates with the rear diff getting locked.
For what its worth, my Gen 1 Tiguan just came back from a Haldex / DSG service, and now sounds like its locking the rear wheels during tight turns. It's quite noticeable, wasn't doing it before it went in for a service, and I'm sure is awesome for tyre wear too. I'll be contacting my mechanic next week, if I find anything I'll advise here, although I'm aware we're discussing a later model vehicle.2012 TDi DSG Tiguan
2011 TDi DSG Octavia Wagon
I think it may be the new haldex software but servicing your haldex shouldn’t update/change this.
Most they should do is change the oil and filter.
So... An update. Went back to them, they confirmed it was an issue, and offered to drop the fluid and change it over straight away. Apparently their supplier gave them Fuchs specific Haldex fluid, changed it back to whatever the OEM VW stuff was, and the issue disappeared.
They're an independent rather than a dealer, but it was all resolved quite quickly.2012 TDi DSG Tiguan
That’s interesting.... not sure if it’s the same issue I’m having in the gen2 or if it’s how the programming HD been done.
Originally posted by Simonr23 View PostMy diesel Allspace has the same strange noise and feeling at low revs, medium engine load, up to about 40kph. After that it gets drowned out by engine noise.
Edit: My passengers can’t notice the noise so far even if I pinpoint it when it happens so it’s not that prominent overall to non-VAG trained ears.Last edited by vdubbed12; 27-06-2020, 05:11 PM.MY20 Tiguan Allspace Black - R-Line, S&V, Pano roof
MY11 MK6 GTI Black - Leather, Sunroof etc.
MY17 MK7 Golf 92 TSI
MY18 Mazda CX-9 Touring AWD (For sale)
Originally posted by tigger73 View PostWhen turning corners from a stationary start (first gear), it feels/sounds like the transmission is binding up similar to a 4WD diff lock. I'm getting noises from the rear diff and on some occasions scrubbing sounds from tyres.
I'm getting the dealer to take a look at it as it doesn't feel right. Just wondering if anyone else has experienced a similar issue.
Edit: The noise is there on turning right as well from standstill. I realised it’s the same type of noise I hear on accelerating in a straight line in all gears under 2000rpm especially when engine is warmed up. Maybe I need to post a new thread on noises.
Sent from my iPhone using TapatalkLast edited by vdubbed12; 29-06-2020, 02:03 PM.MY20 Tiguan Allspace Black - R-Line, S&V, Pano roof
