APR Tune - 162TSI - worth every $$
  • Originally posted by OZROD View Post
    Just a quick update, I finally got out onto the open roads this morning and gave the Stage 1 tune a real test. What a difference! It takes off way quicker, and it's starting to feel smoother in local traffic as well. Now I'm really curious about Stage 2
    Happy to hear you’re enjoying your tune. Try a launch (launch control) and you’ll get really excited....
    Stage 2 will give you a bit more torque and increase the area under the curve. Should be sub 5s 0-100 with stage 2, based on stage 1 getting around 5 flat.
    Dr. Mod has diagnosed you with a case of the mod bug!! Only one way to cure it....
    VW Tiguan 162 TSI Highline w/ R-Line & DAP. Mods: OEM IS38 turbo, APR IS38 98 RON ECU tune, TVS Stage 2 + with custom TCU tune, APR Downpipe and resonator delete, APR turbo inlet, VWR turbo muffler delete, APR pendulum mount, APR dog bone insert, APR Open Pod Filter (MQB), RAMAIR intake tube, APR Red Ignition Coils, NGK R7437-9 Spark Plugs, DBA T3 slotted rotors front and T2 slotted rotors rear, ATE ceramic pads front and rear Vbox: 0-100 4.1s
    • Originally posted by Melbourne_Tiggy View Post
      I get the impression that all an ECU chip update does is increase the turbo boost
      • APR Tune - 162TSI - worth every $$
        Boost, fuelling, ignition timing, throttle position maps, etc.
        It’s not quite as simple as just requesting more boost. There’s literally hundreds of tables within the ECU and each one can be modified.
        - Tigger73's 125TSI Build
        • Sorry for the noob question. What does APR stage 1 involve? Just the ECU tune with no hardware mods?
          • yesssssss
            Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
            • Yep, it's a 40 minute software update to the ECU.
              • Originally posted by tigger73 View Post
                I agree
                What I meant was, every time VW release an improved kw engine (2018 Golf GTI 169kW -> 2019 Golf GTI 180kW) all they are doing is modding the ECU
                I expect the Tiguan ECU can be modded all the way to the equivalent of the 2019 Golf R (213kW/380Nm)
                I suspect VW have this kW contingency as marketing fodder for annual vehicle improvements with no change required to engine, tooling or engineering
                • Originally posted by FastMitch View Post
                  I agree
                  Actually, no,the GTI engines from 162kw (which is the Tiguan engine) to to 169kw to 180kw are all the same mechanically but the Golf R engine is not. It has different components, most notable a bigger turbo as standard. Aftermarket tunes can certainly get you to Golf R power levels and beyond, but I think this type of power exceeds what VW is prepared to live with for the components the GTI engines. They do have to provide a warranty for the engine, whereas the aftermarket tuners do not (unless you pay a lot extra).
                  Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2018 MY18 Golf 110TSI (150TSI) Trendline manual White2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
                  • Gti 40 years pumps 195kw from factory, is it stil same engine as Tiguan??
                    • Originally posted by LJ1981 View Post
                      Its not, its actually a detuned Golf R engine.
                      • So pretty much it’s golf R but FWD
                          Yes and about 200kg lighter .....
                          • Hey, has anyone heard of/installed this ECU tune/remap: Volkswagen Tiguan 162TSI Tune, ECU Tune and ECU Remap from Superchips Australia $800
                            Interesting in feedback. Seem reputable.
                            Superchips Volkswagen Tiguan 162TSI ECU Tune & ECU Remap (162 kW)(May-16 onwards)
                            • Originally posted by tiggeroz View Post
                              "This is an extremely powerful and quality tune bringing final figures to over 200 kW!"
                              Website says you first send a copy of your current ECU and then they send you a tweaked ECU back within 3 days
                              1) Can you flash back to original prior to servicing ?
                              2) Can you flash multiple times ?
                              • Generally the Superchips tunes are fairly conservative tunes and don't push the envelope too much.
                                They're reasonably well priced but I would expect them to perform just a little bit above a JB4.
                                It's a budget tune and you generally get what you pay for.
                                Yes I think you can flash back to stock. As long as it's the same car you can flash multiple times. Which is one benefit. There are a number of other tuners out there that can supply similar hand-held controllers which allow similar functionality in terms of loading files.
                                No guarantees that it won't be detected even when you flash back to "stock". With some of these handheld devices your flash counter increments so it's a bit of a give-away that it has had the ECU written.
                                Personally if you're going to get a tune I would be getting one based on best performance, convenience, ease/cost of updates and support.
