The other day I was asked to activate the DRL switch in the MFD and the coming home function in the #09 BCM module in a 2015 Amarok. I went into the long coding and changed the various bytes and bits but when it came to saving it. It rejected the new coding saying it was out of range anybody encountered this?
VCDS tweaks for the Amarok
Are you using non-zero values for workshop code and importer? Vcds up to date?
Sent from my HTC One_M8 using Tapatalk2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
I'll have a look. I have DRL and Coming home active in mine. Its MY14 Amarok, but that should still be OK.Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
Yes using default 0 values was thinking of configuring VCDS before hand to use the Amarok factory values which VCDS gave me the option of using instead of 12345 123 etc.
I was using the latest version of VCDS as I just bought a 10 inch Toshiba tablet off eBay for $200 and was testing this as my laptop battery has given up the ghost. I was able to successfully recode his RCD 510 radio to use the RVC he had just installed. Will post the details of his BCM module later as I am using my iPad at the momentLast edited by Bambazonke; 31-05-2016, 02:43 PM.MY 21 T Cross 85TSI Life| Makena Turquoise | Driver Assist Package |
Mods: VCDS tweaks |
Some modules will reject coding if you are using just zeroes for WSC. 12345 123 is fine for them.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Here are the details of the module
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R7 937 087 P HW: 6R7 937 087 P
Component: PQ25 BCM H30 0565
Revision: -1------ Serial number: --------------
Coding: 640002380C210000003808102C4B84C50080410E6002000030 0000000003
Shop #: WSC 07456 000 09999
VCID: 51A2976808E0ABB6AE-8004
Subsystem 1 - Part No SW: 6R0 959 802 M HW: 6R0 959 802 M Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 002 3323
Coding: 050000
Subsystem 2 - Part No SW: 6R0 959 801 P HW: 6R0 959 801 P Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 002 3323
Coding: 050000
Subsystem 3 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Component: E221__MFL-TAS H31 0037
Coding: 820000
Subsystem 4 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3323
Coding: 000000
Subsystem 5 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3323
Coding: 000000
No fault code found.
J you may be right as the importer code is 000. I have also noticed these factory values differ from earlier Amaroks that I have scanned previously.Last edited by Bambazonke; 04-06-2016, 07:25 AM.MY 21 T Cross 85TSI Life| Makena Turquoise | Driver Assist Package |
Mods: VCDS tweaks |
