2012 VW amarok 2.0L tdi bi turbo
Symptoms: on first drive of the day, cold engine. Change out of first gear and can hear a very loud screech from the engine.after that driving around can’t hear the screech again until the engine is cold.
[emoji3544]Possible cause: I think it could be the turbo turbine contacting the casing because of too much freeplay.[emoji3544]
-the larger turbo turbine has slight amount of freeplay. I’m not sure if this enough to make this type of noise though.
How do I know what turbo it is ?
Wish I had a microphone kit so I could put a sensor mic at each turbo.
Has anyone else experienced this issue with the amarok engines ? Engine code CDCA
