Hi all,
First post here for me, a new member. A couple of months ago, I had a lousy run with vehicles. One week my bike blew up and the next, the Amarok. Its a 2012 CDCA 4x4 dual cab TDi 400 Rok with 235k harder km on it. I had a timing belt let go 18 months back (20k km ago) and I spent $7k AUD having it repaired and rebuilt. Given the age/mileage and condition of the vehicle, I do want to fix it again yet this time a mechanic friend and myself will swap the motor instead of a repair. I won't spend too much effort explaining the failure of the motor other than its a major failure in the top or bottom of the engine, I'm pretty confident that its stuffed and just want to swap a fresher motor from a wreck. A repair of the original motor is off the cards. I may have picked up some bad fuel and will send away a fuel sample but even then, I'll swap out the motor. The details of my ute are as follows:
2012 4x4 TDi400
CDCA motor
Note: nothing is externally obvious re: the engine failing - the serpentine belt is in situ, etc.
Given that my mate and I can pull the motor out of the truck and put a new one in, what parts will need to be replaced?
What consumables will we need to order ahead of the job?
What parts have to be retained from the original motor (i.e. I have heard that the four fuel injectors are mapped to the ECU and will need to be remapped with a VW computer if we swap injectors)?
Any advice will be appreciated. Ideally we will need to do this engine swap in a weekend as the ute is sitting in the farm shed 300km away from where we live. Whatever we will need will have to be ordered well in advance. Thanks,
unclemitty
2012 4x4 TDi400
CDCA motor
unclemitty
