So With trailer assist and no rear view camera the camera is actually there it just has the video feed loom missing , went to vw and asked if they do just a video feed loom, they don't do any looms that's not supplied with the car, so got the loom out of my camera kit (the loom is for sale on UK eBay for £65) and cut away everything that was not connected to the video feed lead, plugged it in then ran the cable to the mmi, connected the white and black wire to the blue plug, you have to remove the quad lock, pull out the blue plug from the quad lock by moving the little lever that clips it into place, then there's 2 locking covers that you have to flip up (fiddly) and then the pins slot in
Next is the obd11 bit
Camera system rear view
Long coding
Then select the long code up in the top right corner
Scroll along using the green arrows at the bottom of the screen till Byte 7 -parking mode (quer) select the box
Press and hold the green tick
Infotainment
long code
Scroll down to
byte_19_rear_view_low
Change to activated
Then reset the discover pro by pressing and holding the on/off button until the screen goes off then back on again saying welcome to Volkswagen
Also noticed the parking sensor screen is transparent (some people are complaining that it's black and can't see 1/4 of the picture)
Hope this helps
Long coding
Infotainment
long code
Scroll down to
Change to activated
Hope this helps
