What is MY16 TDI Fault Code - "Cooling fan for housing" ?
  • What is MY16 TDI Fault Code - "Cooling fan for housing" ?
    Hi guys,
    I just bought a VCDS cable and scanned the car. To my surprise, a few fault codes are presented in the auto-scan report.
    All but one comes back again and again after clearing DTC.
    The report looks like this:
    Address 5F: Information Electr. (J794) Labels: None
    Part No SW: 3Q0 035 846 HW: 3Q0 035 846
    Component: MU-S-N-ER 820 0611
    Serial number:
    Coding:
    Shop #:
    ASAM Dataset: EV_MUStd4CDELP 001001
    ROD: EV_MUStd4CDELP_VW26.rod
    VCID: 6EFD3AD0B171734EBF-803A
    Media Player Position 1:
    Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
    Component: ABT_Std-2_Nav H43 4060
    Serial number:
    Engine Control Module 2:
    Subsystem 2 - Part No SW: 3G0 919 866 K HW: -----------
    Component: MRM2 2015/16 --- 0420
    Serial number: --------------------
    2 Faults Found:
    1559 - Cooling Fan for Housing
    B126B 01 [008] - Electrical Failure
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 18
    Reset counter: 48
    Mileage: 8 km
    Date: 2015.09.24
    Time: 00:03:39
    Anyone knows what this is?
    Appreciate any input.
    cheers
    Originally posted by nsk_john View Post
    Hi guys,
    Code:
       Serial number:
       Coding:
       Shop #:
       Serial number:
    2 Faults Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 18
                        Reset counter: 48
                        Mileage: 8 km
                        Date: 2015.09.24
                        Time: 00:03:39
    cheers
    John: hello . I've not seen the fault code before, but it reads fairly clearly as follows:
    • It's most probably related to the fan that cools the electronics in the infotainment unit enclosure that lives inside the glove box
    • The fault first occurred when the car had travelled just 8 kms. So it happened when the car was new (probably first leaving the factory)
    • You can't clear the DTC because it has occurred on 18 separate times since the fault was first stored.
    • The reset counter means that the car has to experience 48 problem free cycles before the DTC clears itself
    • The priority rating of 6 means that it's not a crucial fault - VW's rating 6 means that the fault has a long term influence on drivability.
    Clearly it's something that needs to be looked-at by your friendly (but sadly, incompetent) dealer service manager because if left unattended, the increased temperature inside the infotainment unit will degrade the electronic components and eventually they will fail!
    When you take back the car to your friendly (but sadly, incompetent) dealer service manager, you might want to ask what manner of pre-delivery inspection was carried out.
    I suspect that your friendly (but sadly, incompetent) dealer service manager defines a pre-delivery inspection as a car wash and a smile as you hand over the bank cheque!!
    Don
      Remember, don't mention "The Internet" when you talk to your friendly (but sadly, incompetent) dealer. They will look at you as though you've offended their knowledge of their own car. I had this experience when I was trying to get the voice patch. (Not upgrade, not map version...)
        Eaglehawk: very good point and thanks for the sage advice -It just makes me so mad when car buyers hand-over good money for a quality product and the delivery process is ignored by the seller. It happens so often that little to no pre-delivery checks are done on these new cars.
        I'm not sure if VW dealers are particularly bad, but their practice is predicated on the assumption that buyers don't have the necessary equipment to check for DTCs. How difficult is it to run a quick check with ODIS for DTCs before the car leaves the showroom?
        Don
        PS: I even had one dealer accuse me of voiding the warranty when I showed him a copy of a VCDS auto-scan report from a friend's new GTI that was full of DTCs. The poor misguided service manager had clearly decided that the best defence was offence! Needless to say that I wasn't distracted by his thinly veiled attempt to deflect liability for his omission, and I have to admit that I thoroughly enjoyed our consequential discussion which confirmed my car-wash-and-a-smile suspicion of what constitutes a pre-delivery check!
          Don
          Thanks for the advice everyone. Unfortunately, service of VW dealers haven't improved much over the years. They forgot to remove suspension blocks on my last car, the salesman told me that wasn't a suspension block without a second thought when I went back.
          Fan is relatively simple and reliable part, is it normal for the fan to fail in such short period after passing factory test?
            John: Not sure if you are aware of what's called the "U" curve for component reliability. I apologise if I'm telling you something that you already know, but the "U" curve is normally portrayed as a graph with time on the horizontal scale and probability of component failure on the vertical scale. In essence, the graph demonstrates that the most likely time for component failure is immediately after manufacture and then after a period that is the useful life of the product. In the mid period of the "U", probability of failure is lowest (but obviously not zero). Warranty periods are meant to protect the consumer during the initial part of the "U". The spare part market is focussed on the latter part of the "U".
            Of course, every component in the infotainment box is subject to failure, but my amateur experience with repairing electronic devices has been that generally, well designed electronic circuits suffer minimally from failure of passive/active electronic components (perhaps with the exception of low grade electrolytic capacitors). Whilst I admit that this is a gross generalisation, I reckon that it's the electro mechanical components that are more likely to fail in modern electronic products (i.e. motors that rely on physical bearings and especially in a car, ciruit board and wiring connectors).
            Bear in mind that the fault in your autoscan might not be the actual fan. It could be a faulty temperature sensor, or some part of the switch-on/off control circuit for the fan.
            But all this is of little significance in your case ( except perhaps as an intellectual exercise). The fact is that there is a worrying error message on your new car that should have been picked-up by the dealer as a pre delivery test. Rectifying your dilemma is easy - you just need to make your problem, the problem of your friendly (but sadly, incompetent) dealer. That is the reason why there is a warranty period.
            Don
              Just couldn't accept the fact that I have received two brand new and faulty Volkswagens in a row. A bit relunctant to let them take it apart. I genuinely hope this is just a software glitch and the error code will go away in a few days.
                John:It is possible that (as you say) it "is just a software glitch and the error code will go away".
                But, may I invite you to consider the evidence in the error message as an indication of the probability that that this will happen:
                1. The fault was first logged when the car had travelled 18 kms
                2. From the time of the first error message, the fault has been re-logged 18 times. I don't know how far your car had travelled when you made the autoscan report, but you can do the math to determine the frequency per km travelled, or the days elapsed per fault.
                3. The error message says that the DTC will not reset until there has been 48 trouble free cycles of the car
                Sounds like a long time to wait to validate your desire- sorry for being so blunt
                The other advantage of taking the problem to the dealer now is that the fault is present, so the warranty claim is evident. If the fault becomes truely intermittent, then it will be difficult for the dealer to validate the warranty claim with VW Australia. Worst case scenario is that the fault does clear and that it re-appears in earnest after the warranty period - not good!
                Conclusion (IMO) - take the car back to your friendly (but sadly, incompetent) dealer and exercise your right under consumer law! I suggest that you express an appropriate amount of indignation (to the dealer) given the events to date
                Don
                  Don
                  Don,
                  You are right. The car should be sent to the dealer when the fault is still on surface. I will update their finding later.
                  Thanks again for your insight on the report.
                  Cheers,
                  John
                    Have you found a solution for this fault? I am getting the same one
                      I doubt it unfortunately. This was a classic case of someone joining the forum simply to get advice on an issue and then they disappeared once the issue was fixed. So they provided no solution/context to the issue once it was sorted and they were never to be seen again. The last post on this thread was in 2015 so I doubt you will get a reply from the original member, and quite unlikely they even own the car anymore.
                      B9 Audi SQ5
                        I'm always puzzled when folk allege that they have the same fault as someone else -because a fault has so many different aspects that it's difficult to have two unconnected error-messages with exactly the same characteristics!
                        hmm......this ain't a particularly difficult error-message to diagnose - clearly as I said in my response to OP, the problem is almost certainty with the internal fan inside the 5F module (which is the MIB - the black box inside the glove-box).
                        This is where the fan is located in the MIB:
                        So, to pursue discussion further - you need to provide more words:
                        1. what part of OP's fault is the same - is your fault status intermittent, or static?
                        2. What diagnostic device are you using- post up a copy of the error-message?
                        3. Have you tried testing the operation of the internal fan with your diagnostic device?
                        4. If the internal fan needs replacing - will you do this yourself, or do you intend to throw money at a professional?
                        Don
                          This error message is related to a cooling fan issue in a vehicle, specifically pointing to an electrical failure. Here's a breakdown of the details:
                          Fault Code Explanation:
                          Fault Code: 1559 - Cooling Fan for Housing
                          This indicates a problem with the cooling fan that is responsible for cooling a specific housing (likely an ECU, battery pack, or another component needing cooling).
                          B126B: This code is related to a cooling fan circuit failure.
                          01: The sub-code suggests an "Electrical Failure," which could mean a wiring issue, a bad connection, or a faulty fan motor.
                          [008]: This might indicate the severity or category of the fault.
                          Additional Details:
                          The issue has occurred intermittently but has been confirmed through diagnostics and has been tested since the last time the memory was cleared.
                          Freeze Frame Data:
                          Fault Status: 00000001 → The fault is currently present in the system.
                          Fault Priority: 6 → This priority level suggests it is not critical but should be checked.
                          Fault Frequency: 18 → The issue has occurred 18 times.
                          Reset Counter: 48 → The fault has been cleared 48 times since it was first detected.
                          Mileage: 8 km → The fault was first recorded when the vehicle had 8 km on the odometer.
                          Date: 2015.09.24 → The date of the last occurrence.
                          Time: 00:03:39 → The timestamp of the last occurrence.
                          Possible Causes:
                          Faulty Cooling Fan – The motor may be failing or have an internal short circuit.
                          Wiring Issues – Damaged or corroded wiring or loose connectors in the cooling fan circuit.
                          Blown Fuse or Relay – A blown fuse or a malfunctioning relay could prevent the fan from operating properly.
                          ECU or Control Module Issue – The module controlling the fan may not be functioning correctly.
                          Power Supply Issue – Voltage irregularities could be affecting fan operation.
                          Recommended Actions:
                          ✔️ Check the cooling fan operation – Manually test if the fan spins freely and listen for unusual noises.
                          ✔️ Inspect wiring and connectors – Look for any loose, broken, or corroded wires around the fan.
                          ✔️ Test the fan motor – Apply direct power to see if it runs properly.
                          ✔️ Check fuses and relays – Ensure no blown fuses or faulty relays are preventing operation.
                          ✔️ Scan for other related codes – There may be additional fault codes pointing to a root cause.
                            What? Are you moderating Lucas?
