Caliper size for Rear Calipers for non PP GTI
I'm wondering if anyone out there has tried to upgrade the rear calipers on a standard MK7 GTI at any point. I recently upgraded the front brakes with PP Calipers and some ECS 2 piece rotors. I went to do the same with the rear however the parts I ordered turned out to be for a manual hand brake rather than the electronic brake. I"ll need to return the rear calipers as they aren't much use to me but does anyone know if there is any difference between the PP and Non PP when it comes to models with the electric rear park brake? Eye balling the rear rotors at the moment and the braking surface area seems to be identical which suggests the rotor diameter is the same, of course the rears are solid and not vented unlike the replacement rotor's I have so it's a different thickness (22 vs 10).
