Originally posted by steve2209
View Post
Without knowing first hand, I suspect VW Australia chose to offer the USB/Aux-In interface instead of the Media-In for a number of reasons. I had a Media In interface some years ago in a Golf Mk5. Apart from needing a separate cable for each of your devices (iPod, USB etc), the cables were expensive and especially the Apple cable did not work with all devices properly (i.e. for me it did work with an iPod Classic but not my iPhone 3GS or 4). If you look at European fora at the moment, you will find that people are also having compatibility problems with the Mk7 Media-In interface and especially with the iPhone 5 and 5S needing newer versions of the cable etc. I know from first hand experience that BMW experienced similar problems with their USB interface in the E90 series when the iPhone 5 came out.
Also you need to remember that a lot of people don't have iPhones or iPods and for them the easiest way to connect a device is a (very cheap and ubiquitous) 3.5mm cable. Yes, you lose the ability to control the device on the touchscreen of the car but if that's really important to you then you can have that using an SD card instead. The SD card will also work faster. That way you also have the USB port free to charge your mobile phone and also take advantage of the inductive phone aerial that works in the little cubby in front of the gearshift knob. Failing that I'm sure that in a few months we will see someone will have swapped the USB/AuxIn interface with the Media In with not a lot of difficulty.
