Yep I have both mine and my wifes phone synched at the same time
Mk7 iPod Compatibility (MDI, Bluetooth etc)
It's probably fine for pop music or radio. But as I said, the compromise is one that is not needed and just VWA cutting costs again.Originally posted by scobb View Post320 Kbps CBR MP3. In my opinion, that's more than adequate for use in a car, given that you are hardly in an audiophile environment.
Incidentally, I do use FLAC when listening to my home stereo.Audi S3. Sold
Golf R. Sold
Citroen DS3 Dsport. Sold
2016 Skoda Octavia RS Wagon.
Thanks. Well as I'm sure you are aware it can't be equal to CD playback then but that's fine if your happy with it.Originally posted by scobb View Post320 Kbps CBR MP3. In my opinion, that's more than adequate for use in a car, given that you are hardly in an audiophile environment.
Yesterday I tried a thumb drive and an SD card with a couple of m4a (apple lossless) albums but the GTI comes up with file error or no files available despite the manual saying these files are supported.
, please don't tell me it's some issue with Apple computers.... And I really don't want to convert the entire library.
Apple lossless uses a different codec (ALAC) with is then put into a m4a container.Originally posted by Blybo View PostThanks. Well as I'm sure you are aware it can't be equal to CD playback then but that's fine if your happy with it.
When the manual says it supports m4a it means Mpeg-4 Audio, aka AAC placed in a m4a container.
High bitrate (256+) AAC passes blind tests all the time with much better sound systems than a stock golf... A2DP usually sounded terrible because the digital to analogue converters in the BT units were only really intended for voice, but the later VW units are much better.MY16 Octavia RS 162 Race Blue Combi
Is this a solution to iPhone mk7 golf integration ? MEDIA - IN MDI - Golf 7 5Q - iPhone 5 5S / iPod - 5N0035554GWhite MK7 Golf Highline with Bi-Xenons
I would say so! Contemplating similar for when I place my order.Originally posted by midlifecrisis View PostIs this a solution to iPhone mk7 golf integration ? MEDIA - IN MDI - Golf 7 5Q - iPhone 5 5S / iPod - 5N0035554G
I believe the Discover Media might play FLAC - has anyone tested this? The Discover Pro certainly can, even though it's undocumented.
That's a bugger. I'm currently converting my entire library to 320 AAC so I can drop it on a SD card... I hope the artwork isn't too large, that will be a big task to manually change 370 albums.Originally posted by readerr0r View PostApple lossless uses a different codec (ALAC) with is then put into a m4a container.
My iPhone 5 has 256 versions on it to save space as per ITunes option when syncing. In my car (a Territory) I have a separate iPod classic connected directly and it plays the ALAC versions. A glitch on a country trip on Tuesday meant the iPod connection didn't happen for 30 minutes or so so I had to use bluetooth streaming from my iPhone. Sounded terrible compared to the ALAC versions. Not sure if the Territory supports the A2DP or not though.
My Territory does have Focal splits and an integrated 2ch amp and 8" sub under the passenger seat. Fair bit of Dynamat inside the front door skins too.Trying to convince the wife to do similar with the GTi, but waiting till the factory speakers are fully run in first.
