Mk7 iPod Compatibility (MDI, Bluetooth etc)
  • Old school is out...
    So if I'm understanding this all correctly, I'll need to copy all of the tracks from my iPod Classic to an SD Card if I want the same functionality as I currently have with the iPod in the Polo? And I though the RNS510 system in the Polo was bad?
    If this is correct, anyone know how to convert 8,000 tracks to MP3 without having to create duplicate files in iTunes?
    Gone: Aug 2013 Build MY14 Polo GTI | Candy White | RNS510 | Panoramic Sunroof | Bi-Xenons | Rear Parking Sensors
    Current: Late March 2015 Build Mk7 Golf GTI Performance Pack | Pure White
    • And if I've got this right, with this new fangled iTunes Music thingy, copying music to an SD card is no longer possible (my current method from iTunes) and I have to keep 'off-line' songs on my iPhone and Bluetooth them to the car? I'll get one of my kids to do it for me...
      Looking for:- RS4 B7 Avant.
      Current:- Amarok V6 Sportline; Mazda CX-9 Azami AWD
      Previous - Mk 6 R manual; Mk 7 R manual; Passat 130 TDi Wagon. Mk 7.5 Wolfsburg Wagon.
      • Those using iTunes try these:
        1. Back Up in .mp3 format
        2. Back up your iTunes library by copying it to an external drive
        It worked for me.
        • Does anyone know what version of bluethooth comes with MIBII?
          • Originally posted by SIRIoz View Post
            3407 According to the System Information.
            MY16 MK7 Golf GTI
            - Manual - Sunroof - Folding Mirrors - Lock/Unlock Chirp - 4x Indicator Flash - Traffic - MK7.5 LED Tail Lights with Sweeping Indicators - Dynablink Sweeping mirror LEDs - White LED's on rear rego plate -
              Hey SIRIoz, I'm guessing you're after the Version Number e.g. Bluetooth v2.1 or Bluetooth v4.0 etc.
              Sadly I cannot find anything about it on the web, even tried finding documentation to see if CarPlay requires a certain version. I can although find the new iPhone 6S uses Bluetooth v4.2 and the iPhone 4S, 5, 5S & 6 has v4.0
              However, CarPlay is only compatible with iPhone 5 and above. There is a claim stating it needed the extra ability of the Lightening (cable) connection to run CarPlay. I have found articles that state the iPhone 4S will support the wireless CarPlay, not 100% sure the iPhone 4S will support CarPlay on iOS 9 though.
              My point is, that to support CarPlay it might require Bluetooth Version 4.0 as a minimum, thus MIBII would have BT v4.0.
              Also I have read the new MIBII system can do 2 paired Bluetooth phones at the same time! (might be one for music and one for phone at the same time, can't find much about that either).
              Thanks Ralfi, I'm guessing 3407 is likely their internal version numbers. Although I'd love to think they are using the latest Bluetooth v4.0 standard or at least v3.0 and not v2.1. Bluetooth v4.0 has been around since 2009 and first introduced with the iPhone 4S. iPhone 4's used Bluetooth V2.1 + EDR.
              If anyone has a way of identifying the Bluetooth Version the new MIBII (CarPlay enabled version) has I'd love to know! Still waiting for my car so I can't test anything.
              Two things,
              1. Can anyone confirm what Bluetooth Version (e.g. v4.0, v3.0, v2.1) the MIBII systems are using?
              2. Can anyone shed anymore light on the 2 Bluetooth devices connected at the same time?
              • Thanks Ralfi and RMBB. Yes after BT version
                • Originally posted by RMBB View Post
                  Hey SIRIoz
                  Two things,
                  1. ???
                  2. Yep, as per manual, 2 can be connected at the one time. I've successfully connected both a Samsung S4 Mini & iPhone 5.
                  MY16 MK7 Golf GTI
                  • I was at my local VW dealer playing with the radios in the MY 16 R line and alltrack (I couldn't find the R) and noticed that you can "disconnect" car play on the radio. When disconnected you can browse the music on the iPhone through the touch screen in a similar way to navigating a SD card. I don't have my car yet so I can't be sure but I assume that this means you can browse the iPod through the display in the dash cluster.
                    This is only worked with my iPhone 6. The radio did not recognise my 4S which leads me to believe you need a lightning cable. Which makes me wonder if I can use my iPod with the lightning port instead of an iPhone.
                    Has anyone else tried connecting an iPod with the Lightning connector to the radio?
                    Edit: I have now had the car for a few weeks and can confirm that USB works if you use an iPod with a lightning port. However I like using carplay for maps and messaging so my iPod will spend its time charging in the boot and I will select songs via bluetooth.
