Have the headlights been improved on the Mk7? They are woeful on my GTD. They have a shadow between high and low beam, as well as just generally weak and poor performance. $3000 should not need to be spent on better lights either.
Headlights - Discussion and Questions
Tags: beam, beams, bi-xenon, bulbs, buy, car, clean, directly, dla, dot, drls, factory, feedback, good, great, gti, headlight, headlights, install, led, light, lights, low, magna, main, market, mk7, night, nissan, patrol, problem, projector, red, remained, replacing, retrofit, set, solution, spare, successfully, thread, throw, white, xenon
or some higher output headlight bulbs as opposed to the 2.5k xenon upgrade.
Drove home after dark last night in the GTD and almost cleaned up two kangaroos on two separate occasions. Headlights are so poor that I did not see them until they were going past. We don't all live in the suburbs and VW should be ashamed.
I'll probably be getting a mk 7 GTI, as the GTD's been knocked on the head. Will the lights be better? I sure hope so because we have a right to expect cars of this class to have decent headlights fitted as standard, just like cheaper cars do.
While I'm grumpy, I should include inadequate reversing lights in my whinge.
Isn't it a shame that such a great vehicle is tarnished by such an easy fix issue.
All I know is the mk7 looks cheap without the bi-xenon...maybe its due to their ads. so I have added it.
its not only the bi-xenon, also the dynamic cornering lights.
Sent from my C625b using TapatalkMY14 Golf MK7 103 TSI Highline | DSG 7 spd | Pacific Blue | Bi-Xennon | Sunroof | Driver Assist 2 | Leather |
MY12 Passat B7 118 TSI | DSG 7 spd | Silver |
Have a look at your current bulbs.
I drove my parent's mk5 Jetta at night recently and thought the lights looked weak. All bulbs were working fine. I pulled out the bulbs and discovered they were really quite black. Replaced them and the difference is night and day (excuse the pun
Bi-xenons make a huge difference. Every time I drive my wife's car (not bi-xenon) at night I keep thinking the lights are switched off.Looking for:- RS4 B7 Avant.
Current:- Amarok V6 Sportline; Mazda CX-9 Azami AWD
Previous - Mk 6 R manual; Mk 7 R manual; Passat 130 TDi Wagon. Mk 7.5 Wolfsburg Wagon.
I upgraded to bi-xenons on my Mk6 after woeful Mk5 headlights (which were made to look worse having moved from brilliant Toyota lights). Haven't looked back since and don't want a car without them.
Only issue I've had is other people flashing at me as they think my lights are on high beam.GTI | Carbon | Man | 5 door | Leather | 18" Detroit | Bluetooth | MDI | Bi-Xenon
I think they are brilliant. Auto level, steering/cornering, washers, I think they are worth it. When I get into a halogen car now, it seems like it uses candles for lighting
Manual MY12 RB Golf R | Bluefin Stg2 | Milltek turbo-back
2k could give you lightforce HID's x 6 which would light up Sydney from Melbourne.When a man with money meets a man with experience.......the man with experience usually leaves with the money and the man with money usually leaves with the experience.
In that case nothing can justify spending more than $20k on a new car given that greatwall, hyunday and kia are available at $12999-$19999 driveaway. Should be good enough to get u from A to B in style
And nothing should justify spending more than $5 for a meal.
Originally posted by Brew69 View PostNo matter how bad they are nothing could justify spending 2k on Bi-xenons.Mitsubishi Pajero Sport - Super Select 2WD/4WD
MINI Cooper S Clubman - FWD
