Mk7 Golf GTI Discussion Thread
This is a sticky topic.
  • US GTI vs the rest
    Time Bandits: Four Sporty Ways to Cheat the Clock - Motor Trend
    • Can anyone please tell me the weight of the GTI PP? The US boys says it's 30 odd lbs heavier than the GTI.
      Cheers.
      • I believe it's around 40kg heavier than the standard GTI, although I've seen this figure fluctuate from 30 odd to 40. Definitely more than 40lbs, although the comparison in the USA may be skewed by their different specs.
        • Legend, thanks as always Dutch
          • Originally posted by Dutch77 View Post
            According to the "Golf Performance Range" brochure issued by Volkswagen Australian for MY2014 vehicles, the tare or unladen weight of Golf GTI's are:
            GTI Manual: 1313 kg
            GTI DSG: 1324 kg
            GTI-PP (DSG): 1364 kg
            Most of the 40 kg difference in the DSG models can be attributed to the mechanical LSD, larger wheels and discs of the PP model. Interestingly, the fuel consumption specification between these two DSG models is the same for urban, extra-urban and combined, which means you can have your cake and eat it.
            • Originally posted by Mikey1 View Post
              I knew I'd seen the 40kg gap somewhere. I suspect any fuel variance is likely to be 0.049l/100km or less so wouldn't show up in the stats.. or they tweaked the economy for the tests as part of the slight variation in engine tune.
              If the model differentiation exists on Mk8 I'd still only be buying the PP for the xenons now, and then looking what I could do about the wheels.
              • Why do you think the difference in weight between a manual Mk7 GTI and DSG Mk7 GTI is only 11kg where on the Mk6 it is 20kg?
                Nov '15 Polo 81TSI manual white
                • Originally posted by Mountainman View Post
                  I now think the Volkswagen Australia brochure is wrong. Looking at the Volkswagen UK brochure, they quote a difference of 19kg between GTI manual and DSG, and 20kg between GTI-PP manual and DSG. This makes much more sense, particularly if you compare the data for the R in the Volkswagen Australia brochure which shows a 19kg difference between the manual and DSG models.
                  As the original question was comparing the weights of the standard GTI to GTI-PP, the Volkswagen UK brochure specifies a 31kg difference, which explains Dutch77's comments. It should be remembered the UK version of the GTI-PP is fitted standard with 18 inch Austin's, so these will be lighter than the 19 inch Santiago's, which are fitted here as standard. There will be other differences in weight due to different specification levels.
                  • Does anyone know where I can get some paddle extensions for mk 7 GTI PP?
                    • Originally posted by Jerram View Post
                      I don't believe anyone has sourced any yet, surprising given how long the Golf has been released in Europe and Asia for. The US has only just had it released however and they usually drive a lot of the development of this product so wouldn't expect them to be too far off.
                      Worth keeping an eye on the Golf accessories thread in any case as a few others are searching..
                      • You can try 32 degrees south (32deg.com), they do carry some extensions for this.
                        • APR tune released 316hp and 380tq.
                          • Originally posted by Dzl_Dubba View Post
                            Not yet released in Australia, but those are the US figures, yes.
                            For those of us more metrically-minded, those figures are 235kw and 516Nm at the fly, on 98 RON. WHOA.
                            • Originally posted by AdamD View Post
                              Damn, so the early figures floating around weren't far off the mark this time around.
                              I assume this is at least at stage 2 with dump pipe etc?
                              May need to re-think the no-mod policy.
                                Wait till you drive it
                                Stage 1 only, we make more with an air intake. Our AU testing figures back up the US figures perfectly! Downpipe testing shortly!
