Mk7 Golf TSI & TDI - Observations and Questions
	This is a sticky topic.
 Thanks for that. I also googled and came up with this explanation:
 “When you drive, the steering wheel is usually moved a little, not only when steering. A tired driver stops doing this movement. These pauses are noticed by the system and when it happens frequently, the assistant triggers the coffee cup warning.”
 I thought it was because my wife was twitchier but it could also be she's not as "smooth" a driver as me and, so,maybe she over-corrects and this is the reason the fatigue alert pops up?
 Another question: has anyone else experienced this:
 I seem to have damaged the trim around the gearstick between the gearstick and the console, probably by putting stuff in and taking it out, especially my phone. Now there are a few nicks and there are sharp edges and, unless I'm careful, I end up slicing my hand or fingers.
 Has this happened to anyone else? Or just me?
 Any cheap fixes? Tape?
 That trim piece is a separate panel that clips in and out. I’d find the part number and contact a wreckers yard for a replacement.Originally posted by Arturo View PostAnother question: has anyone else experienced this:
 I replaced one of the 4 prongs in the cup holders this way.
 Sent from my iPhone using Tapatalk ProMY08 Mk5 GT Sport - sold
 Thanks for that. In the meantime, electrical tape works!Originally posted by Mattlock View PostThat trim piece is a separate panel that clips in and out. I’d find the part number and contact a wreckers yard for a replacement.
 As this tric still works? No luck in my 18 tiguan or 18 Amarok.Originally posted by DV52 View PostEnable Traffic Information (TMC) on Mk7 Golf - VCDS tweak
 Step 1. On "Select Control Module" option click "Select"
 Step 2. Select "5F-information Elect"
 Step 3. Select "Adaptation"
 Step 4. Using pull-down menu, select "Fee Based Traffic Information (TMC)" channel (it's about 20% down the channel list)
 Step 5 Change default value "0" to ?????
 Edit (30/04/2015): The magic number for Step 5 is apparently "1024".
 This value was initially suggested in sucnip's post below (see #55)
 And the value was confirmed in alanzidan's post below (see #48 - tweak 5.1)The remaining steps in the procedure are:
 Step 5. Enter "1024" into "New Value" box and click "Do It!" tab. (edit: I have seen the code "32771" used in UK models in this adaptation channel)
 Step 6. Click the "Yes" tab in the "Re-code Invalid" screen.
 Step 7. When the screen in Step 5 returns, click "Add to log" to record a copy of the change report.
 Step 8. Click "Go Back" (in Step 5 screen) and exit the VCDS software
 Missing Adaptation channel - Fix
 The channel, Fee Based Traffic Information (TMC) in step (4) appears in the drop-down list if byte 13 of 5F-information Elect. controller has a coding value of hex09. If this channel does not appear, then byte 13 may need to be changed to this value. Byte 13, bit 3 needs to be set for RDS to be enabled as per the screen-shot below (thanks zloybob.):
 Finally, after the changes above have been made, it's a good idea (I think) to reset the infotainment unit as follows: Press the on/off button on the radio until the unit switches off and keep holding down the button until the unit switches on again
 Please note the following after the tweak has been completed:- For TMC to work, "TP" and "RDS" need to be activated in the set-up menu for the radio
- It may take some time for the new facility to be established and for the initial set of traffic reports to be downloaded. In my case, the wait time was over an hour, but others have reported longer times.
 EDIT: Further information from zloybob -
 Thanks
 Sent from my SM-G965F using Tapatalk
 Hi There,
 Keen to get some advice.
 I have a 2013 VW Gold 90TSI Comfortline, I bought it brand new 6 years ago. Apart from burning through oil (which I top up regularly between services) the car has given me no issues. I have done 113,000km mostly FWY to work, it has been very fuel efficient and drives very smooth.
 A couple of weeks ago my engine light and EPC started coming on intermittently. Sometimes both come on sometimes only one, some days nothing. It is very strange as the car drives perfectly no loss of power, no noise when idling it is normal. The start stop function which 99% of the time I turn off, also started coming up with an error. Again no issue with the cars drivability. I have taken it to a couple of mechanics and none of them seem to know what the issue is. They kept saying it could be several different things and we'd need to replace them etc one by one to find the issue. I have been told horror stories about taking it back to VW workshops so I am really worried and just don't know what to do.
 I am also a woman and constantly feel like workshops try to put one over me thinking I would have no idea because I am female. Some workshops charge $150 just to run the diagnostics program, and they don't even know how to fix the errors. At the first place the error code I received was "P00AF Turbocharger/Supercharger Boost Control 'A' module performance"
 Open to advice, help or any ideas on what this could be.
 Regretting my VW purchase!
 Many thanks,
 V
 Hey VSA87, you might be better off asking this question in Whirlpool forums. It’s a lot more active than here Attention Required! | CloudflareOriginally posted by VSA87 View PostHi There,
 Many thanks,
 V
 Alternatively there’s some Facebook groups.
 Good luck in getting it sorted
 Sometimes it can be very hard to diagnose those sort of errors. VW South Yarra took two months to work out why my 2014 Polo was doing something similar.Originally posted by VSA87 View PostHi There,
 Although it can be frustrating as the owner, sometimes the mechanic has no option other than to start trying to replace parts, which is a logical process of elimination.
 The best you can hope for is an experienced mechanic who will be open with you about their reasons for replacing part A and the potential cost if part B is actually the cause. And C, D etc.
 If you’re in Melbourne, call Alex from Underground Performance, which is owned by a mate of mine.
 But, it may be time to consider offloading this vehicle if your finances can handle it.
 Ben
 Now: ‘19 VW Golf R, ‘15 Polo GTI
 Before: ‘06 RenaultSport Megane 225 Cup, ‘14 VW Polo GTI, ‘12 VW Golf GTI, ‘06 VW Golf GTI, ‘05 VW Golf Sportline, ‘01 Holden Astra SRi, ‘00 Nissan Pulsar SSS, ‘99 Holden Astra CD, ‘98 Nissan Pulsar SLX, ‘91 Nissan Pulsar GL with Q engine swap, ‘80 Subaru LeoneBen
 2015 Polo GTI & 2019 Golf R
 It might be worth using a cheap multimeter or voltmeter to see what the battery voltage is when the engine is running. Normally it should be around 14 - 14.7V if the engine has been running for a while.Originally posted by VSA87 View PostHi There,
 If there is a problem with the charging circuit or the battery leading to too high or too low a voltage then VWs will show all sorts of weird errors as a result. Golf batteries are known to fail prematurely, but 6 years is a reasonable life for a battery.
 If that doesn't show anything wrong then I suggest you take it to a good independent VW specialist to read what error codes have been stored, that will give your mechanic a better idea of what the problem is.
 Maybe some of our Melbourne based members can suggest a good independent mechanic that is not too far from Preston ?2017 MY18 Golf R 7.5 Wolfsburg wagon (boring white) delivered 21 Sep 2017, 2008 Octavia vRS wagon 2.0 TFSI 6M (bright yellow), 2006 T5 Transporter van 2.5 TDI 6M (gone but not forgotten).
 Hello im looking to buy a Golf 7 1,2 TSI Trendline. Although i have some worries with the infotainment system that is currently installed. Does this infotainment system have bluetooth:
 And is it possible to upgrade to the newer infotainment system like this one:
 Please any kind of information would be helpfull. I really want to buy this car but i would love it to have at least bluetooth, and even better the possibility to upgrade it later on.
 I bought a brand new 2012 Bluemotion Golf 77TDI.
 It died last February with 220,000 kms
 I was told by the wrecker who bought for $300 that they all do this around that many kms due to the "plastic" inlet manifold collapsing.
 Not to sure about that engineering decision! but hope this is a warning to many.
 I bought the TDI to save on fuel cost, over 220,000kms thats about $65 per 1,00kms over my last petrol car for a total fuel saving of about $14,000
 Im not sure what I would have sold it for with this many kms but Im not convinced on Diesel as a money saver.
 I have gone back to a petrol car.
 Looks like you might have got about 5-7k for it with that many kays.
 Ben
