I'm not sure if you can with the standard halogen headlights unless you dissect them a bit due to the contact points for the bulbs being proprietary, but with aftermarket ones (such as Ed's Replicas or WinPower) you can put in HIDs and ballasts and have no error codes returned. Obviously without washers or adjustment, HIDs may not be quite legal, but I'll leave that to you.
Intakes for the 1.4L engine are going to be tricky to find for a while as it is quite a new unit, if you *really* want one you can probably get one custom fit for you. As for BOVs/aftermarket diverter valves, see my thread here: http://www.vwwatercooled.com/forums/...si-103061.html - it seems the 1.4L engine does not have a factory valve.
