Mk7 Golf R Discussion Thread
This is a sticky topic.
  • Originally posted by kennyc View Post
    Sent him a photo and reckons just bring touch up paint and he will take care of it.
    The first mark always hurts, you should be ok with a good detailer.
    2018 MY18 R 7.5 Wolfsburg | Blue| Sunroof | Finally here! And it's goddam goood!
    2010 Mazda 6 | Luxury Sports | White : Sold
    2009 | 335i | Convertible | Grey : Sold
    2006 Jetta TSI DSG | Highline | Silver : Sold
    • Looking for a bit of DSG advice.
      This is my first DSG in an R. We have a Passat diesel but it gets driven in D at all times.
      On two occasions in the last month I have felt a big bang through the drive train when changing from 1st to 2nd. On both occasions it’s been pulling away promptly, about 3/4 throttle, with the box in M and I’ve pulled the up paddle at around 4000 to 5000 rpm and BANG. There may have been a slight degree of lock on the steering on both occasions - lane changing. No other DSG issues in 1000 kms.
      When I say Bang, I mean it feels like I’ve hit a brick wall or a drive shaft has fallen out type bang and jolt. Very unpleasant.
      Is this something that they just do from time to time, or should i be talking to the dealer?
      Looking for:- RS4 B7 Avant.
      Current:- Amarok V6 Sportline; Mazda CX-9 Azami AWD
      Previous - Mk 6 R manual; Mk 7 R manual; Passat 130 TDi Wagon. Mk 7.5 Wolfsburg Wagon.
      • Originally posted by Paul_R View Post
        It shouldn't be doing that, does it happen D or S if it's only M still seems strange I would check with your dealer. I find the S in 7.5 DSG is good for most situations.
        2017 MY18 Golf R Wolfsburg | Oryx White | DSG / 2021 MY21 T-Cross Style | S+V Package | Limestone Grey
        • Originally posted by Kachingg View Post
          No the tsi has the 7 speed dry clutch dq200(rated max 295nm with a tune) vs the the new dq381 in the 7.5 golf r , golf alltrack diesel and audi s3 which is rated 430nm normal and 600nm or so with a tune its a beast of a gearbox
          When you say 600nm ‘with a tune’, do you mean a tcu tune?
          • Minor issue on 7.5R.
            When I first turn on the car I can't change radio channel by steering wheel button for the first min or so (doesn't do anything). I can using the stereo touch screen however. Seems to happen on some starts not all. Normal?
            • Originally posted by SW33 View Post
              Yep a new tcu program Harding performance is just about to release its dq381 tune early next year tho they say that the new 7.5 r with the 7 speed vs the 6 speed dq250 they can tune it for a extra 20kw and 80 nm over the plain 7.0 version just because of the beefier gearbox
              Also apparently the tune is optional on a stage 1 tune with 260kw and 520nm! so they think a stock no tune dq381 will handle that much grunt (i have been told by another vw tuner that the clutches in the dq381 are "massive")
              2017 Golf Alltrack 135tdi All options
              • I'm presuming tunes will void the warranty though?
                  I got a different response from them on this question. The increased power/torque was not them doing more aggressive with the tune, but rather something they couldn't explain other than VW coding changes (they confirmed engine/turbo were identical). Have a look at question/comments on youtube video.
                  • Originally posted by WallySimmonds View Post
                    Yup as always if something goes wrong and you have a tune that is picked up its your baby
                    • Originally posted by toggle View Post
                      Hmm that is interesting i did not read the comments i took from the video him saying more power from stronger gearbox i will go back and check thanks
                      • Just dropped my car off to Dan for my paint protection. Will post photos once I get it back 😁
                        MK7.5 R|Lapiz Blue|DAP|Sunroof|Tint
                        SOLD MK7 GTI|DSG|Carbon Steel|Leather|Panoramic Sunroof|Bi-Xenon Lights|Driver Assist|Tint|Euro Plates
                        SOLD MK6 GTI|5 Door DSG|Carbon Steel|Leather|Sunroof|Electric Driver Seat|MDI|Tint
                        • Originally posted by Hole46 View Post
                          I did my Tiguan with OBDeleven.
                          Got instructions on how to do sat nav nag screen off fix using OBDeleven?
                          Have seen some vcds instructions only (5F-> Byte 23 -> 00 (uncheck all) but wasn't obvious to me how to do the same in OBDeleven
                          • Newbie - Help with how to! | OBDeleven
                            2015 Golf R. Lapiz Blue.
                            • Thanks, will try shortly!
                              • Whilst on the subject, anyone tried swapping water temp with oil temp as default on AID?
                                Have seen the odd vcds/obdeleven instruction but unsure if this works on the 7.5.
