I'm looking at buying a Golf 110TSI but don't know how to tell the difference between the 110TSI v 92TSI and other variants. Any help will be greatly appreciated.
110TSI v 92TSI difference
Both the 92TSI and 110TSI look idential and both have a 1.4L turbo engine so honestly some may be advertised for sale incorrectly. I would advise you check either or all of the following to be sure you are buying the correct one:
- owners manual / log book to see how the car is identified as it should have it printed on the inside of the front page.
- inside the boot near the spare wheel there should be a sticker which identifies which model (eg 110TSI) as well as any options the car has (eg alloy wheels, parking sensors etc)
- rego papers as it will state there what model it is.
- do a VIN number check using a service like RevsCheck or CarVertical
The 90/92/103TSI Golf were MK7 Golfs and there were numerous upgrades to the 110TSI MK7.5 Golf, both cosmetically and technically.
110TSI MK7.5 Golfs were built from June 2017 onwards.
Externally, the easiest way to tell is that the MK7.5 110TSI has LED running lights in the headlights, LED taillights and a new styled front and rear bumper and no visible tailpipes. Internally, the easiest tell is the radio is a large full glass style unit, compared to the small unit with a plastic surround in the older MK7s. There are various models (base, trendline, comfortline, highline, R-line) in the 110TSI but the basics mentioned above are all present in all of them.Last edited by Sharkie; 08-01-2024, 09:19 AM.Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
Thank you Lucas. I just bought a 110TSI as the logbook and owners manual clearly stated 110TSI. I was unable to see any label or sticker in the boot area and also checked under the spare wheel. The VIN number check didn't actually state which engine. Cosmetically it seems to appear 110TSI, so thank you for your response. Much appreciated.
Rego check seems to indicate that it is a 2017 110kw MK7.5 manual.Originally posted by Oggi View PostCosmetically it seems to have all the 110TSI. It has LED running lights in the headlight but actual headlight is halogen.Flipper Dog
Now - T-Roc R, Audi Q5
Yep, the full black trim (rear valance) at the bottom of the rear bumper, indicates this is either a base model or a Trendline. And those were the only manuals available in the MK7.5 110TSIs.Originally posted by Flipper Dog View PostRego check seems to indicate that it is a 2017 110kw MK7.5 manual.
The lack of parking sensors then definitively point at a base 110TSI (Trendline has front and rear parking sensors).
It is a good car. We (still) have 1 (110TSI Trendline manual) and after 5 (almost 6) years have had only 1 issue with it being a water pump at 23,000km. No other problems at all!Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
Engine wise the 90/92/103 only has single timing phase cam (intake) and the 110 has timing phase in both cams (intake and exhaust).Golf Wagon MK7 (9092TSI) - Mods: DQ250 swap (Stage 2), 110TSI turbo upgrade (Stage 2), Bilstein B12, 19" Pretoria, GTI PP sway bar upgrades (front/rear), full GTI tartan interior, GTI colour cluster, R Bi-Xenon headlights with AFS retrofit, GTI brake upgrade.
More to come...
