Hi all,
Coolant level has dropped a few times and I finally had time to investigate. Looks like the coolant is leaking from where the lower radiator hose (Part# 5Q0122051B) attaches to the engine.
Attachment plate looks like it bolts onto the block with 3 torx screws and I'm guessing there is an O-ring between that is leaking.
Or am I incorrect and this is a common leak coming from elsewhere?
Is there a recommended site that I can use to look up to see how this is assembled and what part numbers I will need to order? (illustrated parts catalog)
Hope you guys can help.
Cheers, Stellio
Cheers, Stellio
