Upgraded Tail lights
  • Upgraded Tail lights
    Hi All,
    Does anyone know if the 7.5 GTI tail lights will be a direct swap on to a 7 without any harnesses or coding?
    Got the opportunity to pickup some tails but just want to make sure 100% before committing.
    Thanks in advance
    Originally posted by DubSteve View Post
    Hi All,
    Thanks in advance
    Pretty sure its a no. MK7.5 to Mk7.5 only, it more than just coding the wiring is different too. That's why you will see the aftermarket places like SuperNova does MK7 upgrades and MK7.5 upgrades separately.
    VW Golf MK7.0 Sequential LED Tail Lights - Mk7.5 Style - Supernova Lighting
    Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2018 MY18 Golf 110TSI (150TSI) Trendline manual White2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
      Cheers for that, so what you are saying is that if i was to purchase the harness from here MK7 LED Tail Light Wiring Harness Retrofit - Supernova Lighting it should work?
        If you're after the OEM ones, you need to change the wiring harness or use the adaptor and there's coding to be done as well. Else you can opt for the aftermarket ones.
          Yep coding and Harness adaptor required. I have done this on mine. Dean from VW Central Can Help you there.
            If you just wan't to switch all bulbs to LED in an MY16 GTI is this possible?
            Is coding required?
              Is coding required?
              https://i.imgur.com/WgfIUch.jpg
              tiyefah360: Hi.
              short answer is "it depends"!
              Longer answer is: not all retrofit LED lamps re created equal. The module that controls the 35 x exterior lights on your mk7 (is called the Body Control Module - BCM) constantly monitors every lamp for faults. Because LEDs are so efficient in converting electricity to light, they require very little amperes compared to their incandescent counterparts (i.e. the lamps in your current fittings).
              Depending on the characteristics of the p–n junction in the LED (the boundary between the two types of materials inside the crystal of semiconductor) and depending on the nature of the ballast resistor in the unit, this reduced current can be seen by the BCM as a fault if the the BCM is not told that the lamp type has been changed.
              Whether this "false positive" error happens depends entirely on the LED - but if it does happen, the fix is usually not difficult
              Don
