Hi all
GTI my15
The GTI is now out of warranty , so i want to do some mods
The first mod was to upgrade the halogen headlights with ebay UU headlights
I bought them on ebay from uk (advertised as being for halogen VW equiped cars)
these came with HID globes , ignitors, ballasts, preinstalled
I installed the headlights and for about a week everything was fine, no error codes, performed well (no blinding of others . proper cut off on beam height). ...
then my problem
Left (headlight) indicator remained on , even with key off and locked. Indicator on headlight only at fault.
Throws an error in the Headunit when I use left indicator ( clears after cycling ignition)
other left indicators work as normal (mirror and rear indicators) headlight indicator on solid all the time.
I have checked all fuses cannot find anything blown. Engine bay and behind glovebox all ok.
All my search on the web point to the Body control module. Earlier MK6 MK5 point to a relay on the board as faulty, or a dry solder joint. After further research i now understand MK7 have a different architecture . so before i start pulling things apart ( i have found the BCM behind the glovebox)
I have plugged the genuine halogens headlights back in (to see if ebay headlights are to blame ) and same problem, left headlight indicator (stuck) on.
I could take back to VW dealer, pay for a new BCM (if that is the problem), but i want to sort the problem myself, and they probably will say headlight issue, or will refuse to do it as after market.
I can get a second hand module from the states, i now understand there are low line and high line BCM (i believe to do with the HID)
.... so ...
Any ideas ? will a change through vag-com entry fix the issue, or is the BCM already "blown"
Before i starting looking further, maybe someone already knows of the fix, or suggest where to next
Brian
GTI my15
then my problem
.... so ...
Brian
