Originally posted by Hillbilly
View Post
Post speed sign in active display GTi 7.5
For those that want specific advice go here and join and ask your questions in your models subforum
Home | OBDeleven2021 Kamiq LE 110 , Moon White, BV cameras F & B
As OP has said 14117 is the security code for the hex13 module.Originally posted by Hillbilly View Post
Do you know the security code for ACC Control unit 13 please
If you, or anyone else needs further security codes, I've posted a table on the Ross-Tech forum HERE
Hope the table is of use - but more importantly (and my reason for replying) - if anyone knows security codes that aren't on the table (and that have been confirmed as working), please let me know - so I can add to the table.
I promise to include attribution if advised.
DonPlease don't PM to ask questions about coding, or vehicle repairs. The better place to deal with these matters is in the forum proper. That way you get the benefit of the wider expertise of other forum members! Thank you.
Updated my maps yesterday and did some detailed research on the TSR feature. It appears TSR currently detects only speed signs and
"no-overtaking" signs and no other signs. This seems the case even for cars coded from the factory. So no use much wrecking our brains.
I'm now trying to see how I can get the TSR (camera) and maps to work together. I passed a school zone yesterday and TSR detected the 40kph. I then made a left before the school zone ends but the system still enforced the 40kph limit and when I exceeded the limit I started getting warnings on the virtual cluster.
I have come across some sites mentioning the following coding as well:
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21 - Activate
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus - Activate
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification - Activate
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_discla imer - NOT
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off - NOT
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_thresho ld_high - NOT
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill - Activate
In my case I've only done the first three, are the remaining ones necessary?
Also, I dont find these values in A5:
Control unit A5 (front / advance camera)
Adaptation
Display end of speed limit symbol
Importance to activate: Display valid additional signs
View Channel Valid suffix
Corresponding value: 00100111. (default was 100111)
Any thoughts?
Would help if you state with control module its in. From look of that it is in the MIB unit which will only alter what it shows and not do anything to activate thingsOriginally posted by nibose View PostI have come across some sites mentioning the following coding as well:
Adaptation
Any thoughts?
No thoughts mine works2021 Kamiq LE 110 , Moon White, BV cameras F & B
my 2 cents worth......
Australia uses the RoW navigation maps, along with many other countries.
European countries uses ECE navigation maps.
TSR in fusion mode does not complain when being using with ECE maps - it appears they have the necessary data for fusion mode to work.
however it appears the RoW maps are missing the TSR data altogether, hence fusion mode is not happy.
even if someone had figured out the map structure, i don't know how one would create a set of tsr data, specific to australian roads. i'd imagine this would require some sort of hocus pocus voodoo magic!!
so, my conclusion would b - no point flogging a dead horse.
as for pACC (predictive acc), this is a SWaP enabled feature.
i'm not aware of any VW or Skoda models, in australia, with this feature enabled because of tsr/fusion data being missing from our maps. without this map data, it can't be predictive.
so again, no point getting it SwaP enabled (good luck with that to start with).MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
Yes a good explantion I knew that stuff was missing in Aus maps but you explain it better than I could \ ANd yes we are chasing something that isnt there and Im pretty sure it wont see "No overtaking" signs either.
Why Well coming into our village we have a standard roadsign with 10 on it It never notices it because it wont be in the maps but there must be some speed signs in them otherwise they wouldnt change at places where there have been previously but not any longer.2021 Kamiq LE 110 , Moon White, BV cameras F & B
i forgot to mention earlier - this is how it shows "no-overtaking" on mine.......Originally posted by nibose View PostIt appears TSR currently detects only speed signs and "no-overtaking" signs and no other signs.
Must be different on the Skoda then as that hasnt appeared in my Tiguan but then I dont have it in the centre of the AID and my aid has all the other stuff in totally different places.
Will try it but dont know where to find a no overtaking sign anywhere near my home.
Am confused as you show a Skoda but this is the Golf Forum??????
We are all mixed up2021 Kamiq LE 110 , Moon White, BV cameras F & B
Is it possible for you to share your coding? Just trying to understand what could be different in the Golf! How does TSR work in your case, in roads where there are no signs, does it take from the maps?Originally posted by dArK5HaD0w View Posti forgot to mention earlier - this is how it shows "no-overtaking" on mine.......
[ATTACH=CONFIG]47110[/ATTACH]
VW, Audi & Skoda use same set of engines/transmissions and control modules, the variants change depending on the model, so its okay to have a Skoda owner share his input.Originally posted by Hillbilly View PostMust be different on the Skoda then as that hasnt appeared in my Tiguan but then I dont have it in the centre of the AID and my aid has all the other stuff in totally different places.
We are all mixed up
Except I think the Skoda has a Bosch unit in it and thats the difference as has already been explainedOriginally posted by nibose View PostIs it possible for you to share your coding? Just trying to understand what could be different in the Golf! How does TSR work in your case, in roads where there are no signs, does it take from the maps?
