EPC warning light
  • EPC warning light
    Parked for 2 hours came back started drove off then seconds later engine warning light and EPC warning light came on. Seemed to lose power and engine would rev up but car would not respond. Engine light went off but EPC stayed on. Had to drive slowly to get home. It felt like each time I tried to accelerate the clutch was spinning free. Quite worried. What could be wrong?
    2010 | Mk 6 | Golf GTI | DSG | black | 18" Detroit's | MDI
    Go get it scanned to see whats up with her.
      Really needs to be scanned. Could be many things
      Volks Handy
        Thanks. Towed it to VW today.
          hmmm... similar thing happened to us. end result was new engine required.
          see http://www.vwwatercooled.com/forums/...4s4-44540.html
          good luck. i hope its something simple.
            Diagnosed as a faulty coil over one of the cylinders; $380 not bad. Could have been worse.
              EPC warning light
              Unusual symptoms you described for a dead ignition coil. I would not have suggested ignition coils from your info.
              $380 is damn expensive for 1x coil - you can buy 4 for $150. If one has died the others will follow, best buy the 4 and keep them handy.
              R8 Coil Pack (OE/Genuine) 4 pack - BMR Autowerkes - Cars Enhancements, Modifications & Upgrades
                Maybe the engine management system took over when it detected the fault?
                VW charge $100 for the coil.
                Thanks for the link. I may buy that set of 4. Are they easy to fit?
                  EPC warning light
                  Easy to fit and I've got 8 for sale, but not the R8 ones. They are just stock ones from a mk6 GTI.
                  2015 Golf R. Lapiz Blue.
                    I experienced this scenario yesterday, EPC and engine light came on.
                    Though mine behaved slightly different. I have a 2010 Golf GTI and it had been parked most of the day.
                    Started fine as I left my nephews house, had driven maybe 5k's, popped it back a gear to overtake.....Whammo!
                    The engine started to miss, like it had dropped a cylinder or plug. Very sluggish, like little to no pick up.
                    I immediately noticed both warning lights flashing and pulled up as soon as it was safe to do so.
                    Quick phone call to VW service and the guy says, "sounds like you've lost a coil pack"......
                    Did a quick engine check while on the phone to see if she was loosing water or oil, all good there.
                    Engine temp for oil and water were as "normal".
                    Quoted over the phone to replace the full set @ $500 including check??
                    It's booked in for next Monday, thankfully I do NOT have to drive anywhere until then. LOL
                    Greg
                    2015 Golf R
                      That's more like the kind of description to diagnose a faulty coil pack. Save yourself $300 and buy them direct from the link i put a post or two above.
                        Cheers Lucas. Yeah, I would've used your link but kinda needed them quickly.
                        I know online is pretty much the way things are now, but I still like the thought of local shops carrying most parts a guy could need....sadly, not always the case.
                        I mean, to wait until next Monday would've done, but I need to use my car on Saturday.
                        Anyway, after half a dozen phone calls to various part outlets, I got a set (or will have tomorrow) for $280
                        One supplier quoted $540............more expensive than OEM. lol
                        Still, 280 is better than giving VW 500 (possibly more?) so still saving a little.
                        Greg
                        2015 Golf R
