Forum only readable to users
The server is being hammered again by crawlers, we are seeing tens of thousands of "users" online. Rather than give up and take the whole thing offline, I've switched it over so users must be logged in to even read the forum. I've also removed the ads completely once you're logged in since they are now basically worthless and annoying.
It's not ideal, but it keeps things online for now until I work out a better approach.
Service, issues and pricing.
  • Service, issues and pricing.
    Hi All,
    Currently going for a service and some repairs and wanted to know other drivers thoughts on pricing.
    Have been quoted by VW Essendon, $680 for the service. I'm currently at 91900kms on the odometer.
    Issue 1 - Long story short i believe is the Waste gate rattle issue? which has been quoted at $230
    Issue 2 - Instrument cluster backlight has gone and can only use the LCD during night drive, however the needles on the cluster still illuminate red.
    Could be a simple fuse that's blown, however they quoted me for worst case scenario which is a replacement of the
    cluster $800-900.
    Now I did purchase the vehicle through pickles with warranty, not sure if any of these would fall under warranty (see attached)
    If anyone has any recommendations or thoughts it would be greatly appreciated.
    Thanks in advance and apologises for my ignorance.
    Regards.
    I would say take the car in and don't repair anything unless they call you with what is fact not worse case , good luck
    Volkswagen Mk7 Golf GTI 40Y Clubsport
    Tuned by Tarmac Engineering / Spectune
    @ Bayside Performance Services Cleveland Brisbane
      Just had the service done, car does run much smoother.
      Issue 1: yes it was a wastegate issue, however VW were out of stock and needed to order the part. $250 supply/install.
      Issue 2: They gave me the 'bad' news that my cluster globe had gone and needed a new replacement.
      Must be ordered from Germany and costs are $1200-$1300. Well over priced to change a globe.
      Never heard of such an issue to happen on these vehicles before.
        The cluster will have LED's and not globes..... As the cluster also has the immobiliser that bumps the price up. If you do get it replaced and you can get the old one back I will be happy to give you a couple of dollars for it.
