Help me locate this dash rattle in my Golf R. $100 prize for correct diagnosis
    Good choice getting rid of the Mazda, though in all fairness most of the road noise comes off of those potenza's they tend to run.
    Ok then, my idea and it's not a good one: Since the Rattle is always present at that range...........
    Maybe the Turbo??
    2011 B7 Passat Highline Wagon TDI. I Tinted the Windows
      If I'm right (hope I'm not), I think you'll need the $100 more than me )
        Originally posted by Lucas_R View Post
        Haha - funnily enough we sold our 2011 Mazda 3 earlier in the year to buy a Mk6 GTI. The road noise in the Mazda was so bad that you wouldn't have even been able to hear any rattles.
        Actually, something like that used to be a fix for any rattles. Put a ball bearing in the ash tray. It will rattle so much (with the metal ash trays) that it will drown out any other rattle, and you know what's causing it!!!!!!
          Originally posted by anthony View Post
          Rattles in a 2007 Jetta turned me off the brand,I have since had Toyota,Mazda,and Honda products,zero rattles,and I therefore believe their build quality is superior.
          This was my 4th new VW,but literally did my head in.
          Good for you.
            I placed my phone in the little cubby just to the right of the steering wheel. The rattle sounds close to this area.
            Yes i have removed the roof console piece where the sunroof knob/interior lights/bluetooth microphone is as well as the vanity mirrors and lights.
            How about to give the dealer chance to fix it? Or have you already tried?
              It could be the plastic nacelle around the steering column — have had similar rattles from there in other makes.
              Could also be something loose behind the driver's cubby — some of the wiring assembly isn't always where it should be.
              It's easy to pull that out and check — squeeze the sides in and it'll drop down a bit, then just pull hard.
                A little more research done. Google VW TSI Turbo wastegate rattle. Looks like it's common in all tsi golf 6 )
                  I know the wastegate rattle you are talking about, but this is not applicable to the Golf R.
                  I had that rattle on my GTI, its a different sound though.
                    I've had rattlings coming from the vents a few times particularly when driving on coarse roads, they did sound close to what you have in the videos. The bit you move back and forth to open/close the vents vibrate and cause the noise. BUT definitely NOT when I'm cruising on smooth roads. You can hold them tightly while revving and see if anything changes.
                    Another stupid suggestion (well it worked for me) would be removing your sunglasses from the holder above (If you have them there), and be sure they are not responsible. The last time time it happened to me it didn't even sound like the noises were coming from above, it sounded like they were coming from the dash or the gear area. the noise stopped after i removed them. All the best mate!
                    Golf 90TSI MY12, DSG, Candy white, Denver alloys, Pirelli P1 cinturato, RCD 510, R-dash led licence plate lights, 35/40% tinted windows, GTI OEM tail lights, fog lights, Etuners stage 1, chrome exhaust tips.
                      First I thought wastegate rattle, but Actually sounds like number plate rattle but I'm sure you have checked that out. I'm sure this has been done but maybe you need to get 4 or 5 people around the car and just go over everything whilst in that rpm range.
                        Left field suggestion...
                        Windscreen wiper arms?
                        08 Golf GTI - SOLD
                        • #27
                          See pics and info below - unfortunately not.
                          • #28
                            After removing the wipers, plastic cowl, wiper motor and mechanism, Canbus module, ECU and ECU plastic bracket, top of firewall bit last night, im more certain than ever that this rattle is coming from inside the cabin.
                            Took the car for a drive with all these bits removed (except the Canbus of course) and the rattle is still there. Only bonus was that the engine noise was epic with all those pieces missing.....who needs bonnet vents.
                            • #29
                              So you are going to slowly disassemble your car until you find the rattle?
                              08 Golf GTI - SOLD
                              • #30
                                Sorry may have already been suggested or checked but have you checked the structure bourne speaker mount??
                                Noise in your video sounds different but your description of noise location says it could be
