I started changing the rear pads out for new ones, but the piston will not push back into the caliper. Am I missing some trick or something?
1. The parking hand brake is released.
2. Had Wrong Tool to compress caliper piston. (Needed Caliper Wind-Back Tool)
3. The piston is not over extended, because I can still re-install the old pads and put back on the rotor.
4. I even tried opening the brake fluid bleeder valve to let brake fluid out but no squirt even with the caliper compression tool as tight as I can do it.
Cars up in the air and am stuck, Help is greatly appreciated.
