How to display time on the RCD-510 - Golf MK6
  • How to display time on the RCD-510 - Golf MK6
    Hi All,
    I've seen a few YouTube videos where people are able to display the time when the MDI (I believe I have RCD510) is turned off. I swear when I first test drove my Golf GTI (second hand), the time was displayed when I switched off the radio.
    When I finally got the car home, I decided to factory reset everything as the Bluetooth and settings were configured for the previous owner.
    I don't have the sat nav MDI, so I'm not sure if I just imagined this, or perhaps I saw the time displayed at Barloworld when I was first looking at the GTI's.
    If anyone could provide any assistance that would be awesome.
    Thanks.
    My RNS displays the time when the radio is off (and I installed it myself and configured nothing), I can't speak to the RCD, but let's see if someone else can chime in.
      Yeh I've gone through the manual and it does mention to configure the time after the Radio has been configured. I noticed that my setup menu options had changed as well after this.
      I am thinking of installing the RNS, but I think the taillights might take higher priority. But definitely a project worth considering.
        While taillights might be nice and all... you don't see them as often as you will the stuff you see while in the drivers seat.
        I'm a advocate of improving the things you touch and interact with before purely visual stuff (unless of course it's so cheap and easy it's something you can do in between saving for the bigger mods )
        That said, LED tail lights are awesome
          Any one able to help out with this??
          I had another look at the manual and it did mention that the time display will only work on some MDI's. I had another look on YouTube and they do not have the Nav version and look as if they have the RCD510.
          It's not the end of the world, but it's frustrating to know whether I imagined having the time display or if it does work.
          Yep agree with your comment. Hence I'm starting on the interior lighting. Next will probably be the Bluefin tune as that is more of a feel thing opposed to a visual or touch.
            No time on my R or GTI - both have the RCD510 head unit. The only spot where i can display time is on the MFD (top corner).
            I believe it only works on the RNS510 unit.
            B9 Audi SQ5
              Thanks for testing it out for me.
              If you have time, check out youtube and search Golf GTI MK6 Stage 1, there are guys that are recording from the inside the vehicle and they have the MDI turned off and the time is displayed. They have the 3 buttons on each side, which indicates to me that it is not the RNS unit, but perhaps the US models are different?
              Anyways, I think it seems like I must have imagined it.
              Thanks guys for the help.
                US stereo models are different. So dont worry about those.
                I've tried previously to get the time to display on my head unit, but have been unsuccessful. I still think it would be nice to have, but have given up trying. It either can't be done or it's too hard.
                B9 Audi SQ5
                  Yeh it would have been a nice feature, since as you said the only time display is in the MFD.
                  It's annoying for passengers because my missus is always asking me what the time is :\
                  I will endeavour to find a solution, but it ain't looking good.
                    I know exactly what you mean. This was the reason i started trying to find a way to show it on the head unit.
                    B9 Audi SQ5
                      Is the time on the radio when it's turned on? Maybe turn it down instead of off? That way it's free
                        Unfortunately not - the time is not displayed on the RCD510 at any stage (whether its on or off).
                        B9 Audi SQ5
                          BTW the MDI is the component that allows you to connect a USB drive or iPod to your head unit. It has absolutely nothing to do with the time. What you're asking is all about displaying the time on a head unit when it's switched off. And has been discussed elsewhere, that's not an option on the RCD-510, only the RNS.
                            RCD 510 Premium * Clock????
                              Cheers. Thanks for your help. Guess it clears things up on my end.
                              Appreciate all the responses.
