  • Originally posted by GolfR64 View Post
    My Mk6 R has notched up 150000k's and being 11 years old I was thinking if to stick with the Castrol LL 5W-30 or go with another Full synthetic oil,,Also where do I find a well priced Charcoal Canister which I think is in need of replacement...Cheers
    With 150,000km's it might be time to look at moving to a slightly thicker 5w-40 oil, but it depends on whether your car consumes much oil between oil changes. The Mk6 R engines were hit and miss - some burn oil and some don't.
    I got a charcoal canister from ebay (came from China) and it worked well for the year or so I had it before I sold the car. So cant comment on long term reliability.
    Here is a locally available part, obviously not genuine. But it saves you having to wait 4-6 weeks for it to come from China: Carbon Charcoal Canister for Audi A3 TT Skoda Octavia VW Golf Jetta 1K0201801E G
    And here is a genuine one: 1K0201801E - Evaporative Emissions Canister (EVAP) - Audi 8P, 8J & Vol
    – VAGPARTS Australia
    Edit. Found a cheaper option that is in Australia on ebay: For VW Golf Jetta MK6 Seat 2010-2013 1K0201801E Carbon Charcoal Canister Hose AU 6458056156051 | eBay
    • Originally posted by Lucas_R View Post
      Thanks for the tips
      My R doesnt look to sip much oil at all still sitting a tad under the mark and only drive as a weekender with only 4000ks put on in 9 months
      Golf Mk6 R
        Thanks for the tips
        Nothing wrong with sticking with the Castrol if you like it, otherwise there are many other options depending on how deep your pockets are.
        Most of the good quality synthetic oils with the correct VW504/507 spec will be $80-90 for a 5L bottle. Just wait until Supercheap/Repco etc have a sale on and buy a few bottles.
        • Thanks for the tip
          With my car at its mid life would you recommend a 5W-40 grade oil and which brand would you consider
          Also as This is my first R full mark is it on the dot on the dipstick?
          Golf Mk6 R
            Thanks for the tip
            It wont hurt to move to a 5w-40 if you want to, but I would normally only suggest this if your engine is burning oil as the 5w-40 is slightly thicker when hot so it can help slow down/stop the oil burning.
            I have used Penrite Enviro+ for years, they have the correct VW approvals and come in both a 5w-30 and 5w-40 spec. I used to use the 5w-30 in my Mk6 R as it was brand new, then when I had my Mk6 GTI I switched over to the 5w-40 as it was older and used to consume a bit of oil. Now I have a Mk7 GTI and use 5w-30 again.
            Supercheap/Repco etc all stock the Penrite range so its super easy to get, and they do sales every month or two where the oil will be 20-30% off. So I always buy a few bottles when it's on sale.
            5w-30: Penrite Enviro+ Engine Oil - 5W-30 5 Litre | Supercheap Auto
            5w-40: Penrite Enviro+ Engine Oil - 5W-40 5 Litre | Supercheap Auto
            • Thanks for your knowledge
              Golf Mk6 R
              • Sorry for the Double post on the timing Belt..I need to know about the OBDEleven scanning for Timing Belt stretching as in can be used for Timing Chain Stretch..Is this doable and How
                cheers
                Golf Mk6 R
                • Golf R Observations and Questions
                  cheers
                  Timing belts snap or break apart, whereas timing chains stretch and can potentially snap but its rare.
                  If you are worried about the condition of your timing belt, remove the cover and give it a good visual inspection. Look for cracking and other deterioration.
                  Timing belts are recommended to be changed every 5-6years or 105,000km. Its about $1k to change the timing belt (parts, tensioners, water pump and labour) but if it snaps it will cost you a lot more than $1k.
                  Given your car is 11yrs old with 150,000km you should be currently on your 2nd timing belt and getting close to replacing it again shortly.
                  • Yeap it Due in 2025 . Second belt was done in 2018
                    Thanks for the info
                    Golf Mk6 R
                    • Need some insight on brakes on Mk6 R whether to go with DBA or offerings from FCP euro along with pads to suit.Not doing track but just street looking at Solid rotors all around .Also want some input on replacing all bushes . Any and all advice will be taken on board.Thanks to all
                      Golf Mk6 R
                        Need some insight on brakes on Mk6 R whether to go with DBA or offerings from FCP euro along with pads to suit. Not doing track but just street looking at Solid rotors all around. Also want some input on replacing all bushes. Any and all advice will be taken on board.
                        There is absolutely no need to look at importing a basic brake disk replacement from overseas when you can readily buy plenty of options locally. And with how heavy brake disks and pads are, you will pay a fortune in freight costs to bring in from overseas.
                        Have a look on Run Auto Parts who are a European parts specialist supplier. They have Pagid and Bosch brake disks for the Mk6 R. Nothing wrong at all with DBA of course and there are plenty using them, but there are other options. The Mk6 R uses 345mm vented disks on the front and 310mm vented disks on the rear.
                        The Bosch's are on sale which makes them quite attractive from a price point.
                        If you want DBA, then somewhere like Brakes Direct would be a good place to buy them from.
                        Fronts:
                        Front Brake Discs 345mm Hella Pagid 8DD 355 109-541_2pcs for Audi VW Skoda
                        Bosch Front Brake Discs 345mm BD1071 | Run Auto Parts
                        DBA2808 DBA Street Series Standard Brake Rotor (note you need to order 2)
                        Rears:
                        Rear Brake Discs 310mm 54407PRO Hella Pagid 8DD 355 112-121_2pcs for VW Skoda Audi
                        Bosch Rear Brake Disc Rotors 310mm BD1166 | Run Auto Parts
                        https://brakesdirect.com.au/aus/dba2...ake-rotor.html (note you need to order 2)
                        As for brake pads, if you just want a replacement pad then have a look at the options on Run Auto Parts or Brakes Direct. I would recommend a ceramic pad for normal street driving as they are a much cleaner pad (much less dust on your wheels) but good quality ceramic pads like Akebono Ceramic / ATE Ceramic / Brembo Ceramic are more expensive than normal replacement pads.
                        Front pads:
                        Rear pads:
                        As for bushes, I would replace with factory bushes or in some cases, you can use bushes from the Audi TTS which has more solid bushes. Another option if you want aftermarket is Superpro or Whiteline who make polyurethane replacement bushes and control arms etc for the Golf.
                        Here is a link to my old car, a Mk6 GTI. I replaced the lower control arm bushes with the Audi TTS ones. You can see the difference and also the part number if you want to buy them yourself: https://www.vwwatercooled.com/forums...ml#post1033681
                        • Thankyou Lucas for your informative information
                          Do you have links for the Audi TTS bushes
                          cheers
                          Golf Mk6 R
                            If you Google the part number and brand 33971 Febi you will find places in the UK selling them (which is where I got mine from). I found one place locally selling them on ebay Febi Bilstein Genuine New Replacement Wishbone Bush 33973 4027816339731 | eBay
                              dba rotors and dba xp series (light track) are very good.
                              can get on ebay and automotive superstore for cheaper usually than brakesdirect.
                              • COOLANT LEVEL
                                I just noticed my Cold level is about 3mm below "low".
                                My Hot level is a little lower at 5mm.
                                MY handbook states that the hot level may be above the Max i.e. meaning it rises. Is the book wrong?
                                The gauge says the temperature is normal.
                                cars (chronological) Morris850, Morris Mini DeLuxe, Cooper S, Mazda 1500SS, hard times so some old Holden, old Falcon Ute, better times so second hand Lotus Elan +2 (6 weeks, hopelessly unreliable) Chrysler Valiant Charger 770, second hand Datsun 260Z + 2 auto, Mitsubishi Cordia Turbo, Nissan 200SX turbo auto for 20 years(wonderful car burning ZERO oil after 200,000km & no problems when sold.. should have kept it), Toyota GTS 86 auto, now Golf R Mk 7.5 DSG built Aug2018, white.
