Originally posted by HPSOV
View Post
Golf R Observations and Questions
Voice control works on all Nav cars fitted after week46 last year.. As long as its a factory fitted option. Blutooth need not be installed to work as mic is already there in all Nav Fitted week 46 cars. (Golf , Passat , Eos , Tiguan , Jetta) . Does not allow for voice entered street directions because here in aus are maps are not as well programmed (whereis software) as say europe. Version 3 is availble now and its list price is 490 ish plus gst. All cars in the last 4 weeks should have had Version 3 put into. Please see your dealer for your disk if it is not in your glove box. Hope this helps all cheers.Phillip Fairhall
Brand Manager
Rolfe Renault / Audi Centre Canberra
Melrose Drive Phillip ACT
With the R32s it was normal to have the front about 2PSI higher than the rear due to the nose heavy nature of them. With the R being much less so I'd be inclined to having the same PSI all the way around.
Cheers,
Trentsigpic
The little placard says 39 psi all round for normal weights. Up to 42/43 for a fully laden car. Just checked and mine are 36.5 all round as received from the dealer.2010 MY10 Golf R (Sold) - 5 Door, DSG, Rising Blue, Leather, ACC, Satnav, Dynadio, Sunroof, MDI, Electric Seat.
2015 MY16 Golf GTI - 5 Door, DSG, Carbon Grey, Leather, Sunroof, DAP.
I think you should certainly have V3 installed — probably also the CD for it supplied (you should have received a CD with the car — did you?)Originally posted by elisiX View Posthmm.. I picked up my GTI 20th May - no CD in the glove box - no idea what version its running.
2010 built GTI obviously. I wonder if I should have V3 included or provided to me at this stage.
My TDI just had its first service and they upgraded the satnav to V3 when I grizzled about all the mapping errors I was finding — some of them are fixed in V3 but not all ( last Saturday it piloted me into the delivery area of a K-Mart store and wanted me to turn left through the brick wall of the shop — the street I should have been in was 100 metres away and once I got into the right street it knew where my destination street number was.)
Still doesn't include lots of country roads that our cheap portable device knows all about, either (and both units have maps from the same source (Sensis/Whereis) so you'd think they'd be identical.)
As the Yanks say, "go figure".
Thanks for that. My voice control would always give me 'The currently selected language is not supported'. I went into the language setting and it was on 'English (male)', so I changed it to 'English' and voice control works now. But as you say it doesn't support voice control for Nav so its not of that much use.Originally posted by PhillipVWDealer View PostVoice control works on all Nav cars fitted after week46 last year..
I have emailed the dealer regarding the Nav DVD and version.
I'm getting more used to the DSG, todays hiccup was me thinking I was in manual, accelerating off the lights and pushing the gear lever forward for second. Unfortunately I was in D and ended up in Neutral with a revving engine and some funny looks.....
I have also found a major problem with the car that I'm not sure I can live with. The horn. It is the most pathetic, high pitched, wussy, girly horn I have ever heard!!!!!2010 MY10 Golf R (Sold) - 5 Door, DSG, Rising Blue, Leather, ACC, Satnav, Dynadio, Sunroof, MDI, Electric Seat.
You can tell the Nav to turn map on and off though and change scale as well as change compass and also givee verbal radio functions like change station to gold fm.. Even screen off. Even track changes. . Not all bad news.. I have not tried Points of interest on the new version three like petrol stations or Canberra International airport. Try those things and let me know how you go.. All my cars with nav are still in transport mode so I can't try it.. The working one I have is in the showroom so it can't see the sky.. lolOriginally posted by HPSOV View PostThanks for that. My voice control would always give me 'The currently selected language is not supported'. I went into the language setting and it was on 'English (male)', so I changed it to 'English' and voice control works now. But as you say it doesn't support voice control for Nav so its not of that much use.
I have also found a major problem with the car that I'm not sure I can live with. The horn. It is the most pathetic, high pitched, wussy, girly horn I have ever heard!!!!!Phillip Fairhall
Brand Manager
I just tested it on the way home, and you can definitely override D and S mode with the paddles, and also hold down the upshift paddle to get back to D and S auto modes...Originally posted by Dermot View PostNo, Not with Sport mode. Shifting the gear lever into Sport or into Tiptronic overrides the action of the paddles. The car will take its primary instructions from the location of the shift lever.
S Mode is brilliant....
For running the engine in.
I wouldnt want it to labour around at low revs at run in.
Dunno about you guys, But I found that the DSG pattern of change has altered since delivery of teh vehicle.. Or maybe I have...More opportunites have been lost from indecision, rather than wrong decision....
I just discovered another feature of my car!
Despite having 18" wheels I have the black headlights! I only realised when I read on another forum that only the 19" wheels come with the wheel arch lips, but I thought hmmm I have the wheel arch lips. So straight to the garage and sure enough, black headlights, wheel arch lips and missing screws from the wheel arches.
When I picked the car up I did read something in the dealers paperwork that said 'wheel swap', I asked what that was and she just said it came with 19" wheels but they swapped them onto another car. I never put two and two together to realise that meant I got black headlights! I always thought my car looked better than the others
