Guy_H, I have some questions about various APR upgrades for the Golf R and thought I may as well ask here so that other people can find and refer to the information if needed.
I'm considering doing a Stage II upgrade, but I'd like to leave my options open for a future migration to Stage III if possible.
Downpipe:
On the 2.0T STG III - S3, TTS, R page, it mentions that a Stage 3 S3/TTS/GOLF R - Divorced Downpipe is required but not included. The cost is $2495 but it doesn't mention whether the high-flow cat and adaptor is included in that price as it is with the "regular APR downpipe".
Can the Stage III downpipe be used with a Stage II upgrade, or is it only applicable for the Stage III kits?
Also, does the S3 downpipe and highflow cat fit on the R?
Intake:
Is there any advantage to the Stage II Carbonio intake over the Stage I intake? From the looks of things, the stock R piping looks to be quite large and restriction free as it is, and obviously if I went to the Stage III kit later, the Stage II pipe would be discarded anyway.
As a side question to this, the R's engine cover looks to be substantially larger than the GTI's engine cover. It appears that even the intake pipes are covered by a single plastic piece. Can the engine cover still be installed if a Carbonio Stage I or Stage II intake is installed?
Intercooler:
You've stated that the R's intercooler is smaller than the S3's intercooler. Does this mean the R's intercooler is the one used in the Pirelli?
The APR Intercooler seems like a good option if this is the case. I notice that it's designed to connect to the OEM pipes.
There are several forum members (including APR customers) who have mentioned that the OEM pipes are actually a cause of restriction and that changing them even without changing the intercooler can equate to a 3 to 5kw improvement atw. It has been recommended to me to use these two products:
Neuspeed HI-FLO Air Charge Pipe
Neuspeed HI-FLO Turbo Discharge Conversion
What is your opinion on this topic? Do you believe that replacing the OEM pipes to and from the intercooler is worthwhile, and if so, which products do you use?
Thanks in advance
Downpipe:
Intake:
Intercooler:
Thanks in advance
