Hi Michael!
The option i took is to get the latest year engine with low km i could find, aim for a 2012 CAVD engine block with under 50,000km on it. This is just the central block part of the engine.
1. ask around here to find a good local mechanic who has done this before. My local mechanic in Sydney generally does this work for about $1500. Try and find one who's done this a few times. You can by all means go to a VW specialist or Euro specialist but big names can mean big overheads and higher prices. Once you've found the guy, ask if you can have the engine delivered to his workshop in the lead-up to the job.
2. Call the wreckers in and around Melbourne to find the lowest km 2011 or later CAVD block, i got a 2011 CAVD with ~20,000km for $2,000. Let them know you're shopping around and have been quoted that price. Organise for delivery to the mechanic or to your garage. The block weighs about 80 kilos so strong adults can lift it on and off a ute ok. If you need to keep it at your place you can rest it in an old tyre if you have one or rest it carefully on something else.
3. If you want to keep the car, consider getting the spark plugs, ignition coils and high pressure fuel pump updated to the most recent versions. Google is your friend, so is ebay. These were shortcomings of the original engine. The forum can help you with those part numbers, as can you VW service centre or mechanic. The idea is to find the parts cheap by yourself and get the mechanic to install them when your car goes in for regular servicing. In my humble opinion, these cars benefit from 5,000km oil changes/services. When you get it serviced have the mechanic do a compression test every 2nd service or so to track its health so to speak.
I suggest getting either the VW or an aftermarket remap to make the fuel/air mix "wetter" which reduces the running temps. The VW map is a free recall if you haven't got it already. If you do there'll be a sticker on the drivers side door frame (on the car side).
If you don't care either way about having that car, maybe sell it after the work is done and get yourself a TDI instead. The Golf Mk V GT diesel is also a good and fun car thats not too $$$.
4. For extra reading you can refer to Lucifer's guide (same engine) for more info: Lucifer's ultimate guide: 1.4tsi fundamental problems - SEAT Cupra.net - SEAT Forum
Good luck to you man, feel free to ask any other questions in here, hope this is useful for you.
EDIT: Yes any 2011-2012 CAVD engine will do. You just need the central block part, not the peripherals like turbo, supercharger etc. The CTHD engine is just the next version on from the CAVD with upgraded internals like forged and coated pistons. I understand there may be some slight differences but there's a guy here who's done the swap. search the forum for his CAVD CTHD engine replacement thread and hit him up about it if you're curious. I'd only do that if you want to keep the car.
FYI, i put a 2011 CAVD in mine and have tuned the engine for more power. Mine is still running fine with good compression after 50,000km.
