Originally posted by hooba
View Post
Tips for breaking in a brand new engine?
DSG:
When the brake is applied going down-hills with the DSG in ‘Drive’, the DSG knocks down by a couple of gears to allow for some engine-braking.
At first, I thought there was a problem with the gearbox or megatronic unit – I don’t believe this is the case as I’ve read reviews indicating this type of DSG behaviour in other Mark 6 GTI's.
The old MKV GTI DSG was not programmed to do this.
The Mark 6 DSG is proactive in Drive as well as Sport function.
Sometimes the down change in gears is not always welcomed, esp. when its two gears at a time.
On the other hand, I have been using the paddles a bit during break-in period.
Cheers.
WJ
Originally posted by REXman View PostWhat more can I say about it, its a standard feature. The dealer even mentioned it to us when we were buying it a better way than waiting for the temp gauge. Not sure about the manuals you are checking, but it is what it is.
Do you have the car also?
Its a blue light that come's on, and the idea is, when the blue light switches off, you go. You should'nt be driving off really before that. But ofcourse you always have the option to.
But Mazda USA has all their car manuals available online here. As I said, they discourage long idle times and say you should drive away gently after 10 seconds.
Even the Good Driving Habits of the Mazda Australian site says:
"Starting up from cold is when most engine wear occurs. So give your Mazda a few minutes to warm up by using low engine revs as you drive." There is nothing which says 'Excluding the MPS which you should idle for 3 to 6 minutes before driving'.
Anyway, as I said, I'd be interested about what it says in your owners manual, rather than what some sales dude told you about the light.
I reckon though, in the interest of selling cars, a car manufacturer would never narrow its market by trying to suggest that "their" cars would like a 3 mins to warm up. Think of all the practical - I dont care for my car like a mad man - I just want it to go to go" types that would pass.
Engine oil warm = less engine wear
Too long idling = (not good) heatsoak in engine bay
winter in sydney = wait until the temp has risen at least half way to normal, off the cold line and drive calmly for a little.2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
My last car was a 6MPS (same engine as the 3MPS) and there were no restrictions on driving after starting it other than the normal recommendation to avoid high revs until the engine had warmed up. There was however a warning about not switching off the engine immediately after high speed driving, presumably for the normal reason of avoiding post shut down heat soak killing the turbo bearings.
I don't know if its as true these days for modern engines with their accurate fuel metering, but idleing for extended periods of time on a cold engine used to be considered bad as while the cylinder block was still cold, fuel and water produced by the combustion would condense onto the cylinder walls, dilute the oil and be scraped by the rings back into the sump area leading to a) the sump oil being diluted by unburnt fuel and water b) increased piston ring wear. Also the water produced from the combustion combined with any sulpur in the fuel to form a dilute sulphuric acid. This is one of the reaons why shorter oil change intervals are recommended if the vehicle is used for a lot of short trips.
The advice today still seems to be the same - bring the engine up to temerature quickly, but without stressing it.2018 Tiguan 110TSI Comfortline + DAP
Originally posted by REXman View PostIts just a Mazda MPS, 2009 model. It stays on for about 3 mins then turns off when the car is warm.. I guess enough. to go?carandimage The place where Off-Topic is On-Topic
Originally posted by coreying View PostAnd you're correct Idle, it doesn't really do them any harm*, but it just doesn't do anything useful either. Hence why for quite some time now, every manufacturer recommends just driving smoothly/lightly until the car has warmed up. This way you're warming up all the required components of the car, rather than just wasting fuel warming up the engine and nothing else.
*long periods of idling does cause some issues which then require more regular servicing, but ask someone else what those issues are cause I'm not a mechanic.carandimage The place where Off-Topic is On-Topic
Warm-up:
I agree that you should give the motor an initial period of time on idle after start-up for oil to reach & lubricate the top of the motor prior to moving away. This should take no more than 20 seconds. A prolonged warm-up involving having the motor sit & idle is not in accordance with the owner’s manual.
An idle warm up would only prolong the cold oil piston ring to bore friction with excess fuel washing away the oil trapped in the cross hones of the cylinder bores. Driving off after 20 seconds would put some load on the cold motor, forcing out the piston rings, creating some friction, but expanding the piston rings to trap more of the oil in the cross hones of the cylinder bore to combat a rich fuel warm up mixture.
Break-in Period for my GTI:
The new GTI has been driven 3500km in 3.5 weeks with 95% of driving outside metro areas. Mainly tourist routes, highway/freeway, country roadways and at least one protracted mountain climb for about 10-20 minutes on each drive day.
The mountain climbs have seen the oil temp as high as 111 degrees on a couple of occasions, aiding in the expansion of the metal to metal in the motor. It’s also important to gradually reduce the motor & oil temps prior to switch off.
The first 2,000km involved strictly keeping the revs between 2,000rpm – 4,000rpm. The rev ceiling was extended by 250rpm every 500km up to 3500rpm (2500km/4250rpm; 3,000km/4500rpm) - followed by 500rpm limit increase every 500km up to 4,000rpm (3,500km/5000rpm; 4000km/5500rpm; then rev to beginning of redline between 4,000km – 5,000km). This was & will be done by using the DSG paddles in manual mode.
In general, the owner’s manual states that the Mark 6 GTI may use up to 500ml of oil per 1,000km; and during break-in period, the oil consumption may be higher than 500ml per 1,000km.
After 3,500km: The GTI has not used any oil at all. Not a drop.
This is a good sign that the break-in process adopted has ensured that there is enough compression in the TSI motor to ensure that the piston rings have consistently expanded against the cylinder bore trapping the oil. This should also ensure a healthy mate between the piston rings and the cylinder bore, making for less oil consumption in the future when going from mineral based oil to synthetic based oil.
The GTI has finished its crucial 20-30 hours of initial operation crucial to the break-in of the TSI motor.
The GTI can now be used for regular peak hour day to day metropolitan trips if need be in addition to being opened up for some higher revs, once properly warmed up.
WJ
</SNIP>
Originally posted by hooba View PostThank god for the wharfies playing their part in the break in period.
But not sure I can do it myself. I've always gone with drive it hard from day 1 and never let it sit in the same gear or revs for too long at a time. Never had an issue but don't keep my cars long enough.
Breaking-in the TSI motor.
Queanbeyan/Canberra:
Around the ACT I think the Canberra to Batemans Bay drive & return is choice. If times permits – Canberra – Batemans Bay – Bega – Canberra – loop would be a good drive for a break in drive. Plenty of ascents & descents for the motor to load & unload with a big hill climb up the Clyde Mountain (or Brown Mountain if including Bega loop).
Sydney:
I did an easy drive through the Royal National Park (RNP) with 60-80kph zones to ensure all the parts get to know each other for the first 150km. Oil temp usually hovers around 96 degrees, indication not much load on the motor at all.
Second drive involves the freeway with higher speeds & high engine loads with a mountain climb up Macquarie Pass to Moss Vale & return to Sydney, either the same way or in a loop through Mittagong to Picton Road, doubling back onto Mount Ousley and just north of Wollongong (Princes Freeway) for the return journey to Sydney. Saw oil temps range from 91 degrees to 109 degrees on last drive from Sydney to Kangaroo Valley – Moss Vale.
Watching oil temps:
Air temperature varying @ 3-5 degrees between drives does not appear not to affect oil temps to any notable degree.
Kangaroo Valley Mountain Climb
1. The first drive up Kangaroo Valley with 220km on the odometer had the oil temp up to 111 degrees from about half-way up to top of mountain range. After this drive, the motor definitely felt looser.
2. Second drive oil temp hit 109 degrees.
3. Third attempt oil temp hit 107 degrees consistently (short spike up to 109 degree for brief period only).
Similar thing with Batemans Bay drive x2:
1. First drive with one occupant had oil temp up to 111 degrees.
2. Second drive with two on board – oil temps hit 109 degrees.
With the oil temps dropping after each drive, it would suggest to me that the motor is slowly loosening up with less heat friction after each mountain climb. Imo it’s better to keep revs to @ 4,000rpm with light throttle applications and climb a mountain for 10-20min than just thrash the TSI motor out in short bursts. Don’t expect fuel economy to really improve until after 15,000km when mineral oil is discarded for full synthetic oil. Run period, I guess, take the full 15,000km – basically the time the motor is running on mineral oil, which is not as slippery as the full synthetic oil. As stated before – my new GTI has not used a drop of oil in 3,500km in this break-in period. When the GTI is in transit pre-sale - the motor is in transit mode, not being able to be revved past 4,000rpm. This 4,000rpm ceiling is lifted by the dealer pre-delivery - prevents any form of abuse pre-sale.
Cheers.
WJLast edited by WhiteJames; 27-06-2010, 09:47 AM.
Originally posted by WhiteJames View PostAfter 3,500km: The GTI has not used any oil at all. Not a drop.
Question on the break in process and chipping...
Would there be any advantage to getting the APR tune done before / whilst breaking in the engine, or would it be better to break then engine in and then get the tune?
I like the break in drives you went through there too WJ. Had something similar planned myself when I pick the R up (Northern Beaches -> Jervis Bay) and now I know the best hills to hit on the way!
