Oil Sludge
Judging by the readings I have done on the EA888 TSI Golf GTI motor – the ideal operating temperature for the GTI is in range of 95 – 100 degrees Celsius. The oil thermostat does not open until 95 degrees and is completely open at 105 degrees.
Being a MKV GTI owner in the past, I always felt that it took the DSG gearbox about 3 times as long to reach idea operating temperature versus the coolant temp of 90 degrees Celsius. The super smooth DSG changes were always a bit clunky until about 3 times longer than the coolant hitting ideal operating temperature. The addition of the oil temperature gauge on the Mark 6 GTI confirms this. If it takes you 7 minutes for the coolant to hit ideal operating temperature – you’re looking at up to 21 minutes for the engine and DSG oil to reach idea operating temperature of 95 degrees Celsius. It’s not reassuring if you live within 20 minutes drive from work – your oil temperature has just warmed up. Additionally: As the motor is in the process of warming up, some of the pollutants are recirculated back through the motor as an anti-pollution measure required in new vehicles these days, which in the longer term, may cause the oil to sludge-up. Sludgy oil causes motors to seize. It’s always good to change the oil with greater frequency if driving frequent short distance trips.
WJ
WJ
