Drive both and get the one you like best.
I have Mk 6 GTI with DSG.
I read a lot about issues with the DSG transmission (especially at low speeds and on slopes) on the UK GTI forum before ordering my car. I have tried to upset it in all kinds of conditions and have had none of the reported problems. Starting on a hill is no issue at all. It may be that there is variability in the performance of the DSG but mine is perfect in this respect.
I find the actual shifting of the box in drive is not always to my liking although it is very fuel efficient. This is easily solved by using Sport or using the paddle shifters to change when you want.
As per Murphy's issue above, when you hit the gas (in Drive) sometimes the box shifts down rather than building the revs in that gear. Bit hard to describe but the shift is not like a kick down in an automatic and is not ideal. This will not happen if you are using the manual mode or have used the paddle shifters (which temporarily overrides drive). [Just re-read Murphs post and it sounds like he is having the issue when in manual shift mode - I don't think I have this problem but will check it out] It has not worried me enough to play around with it but I suspect you can avoid the issue by feeding the gas a bit more gently.
These 2 minor issues are the only ones I have encountered so far.
I also drove the manual GTI and thought that was a brilliant box but I wanted to try something different and the paddle shifting sounded like it would be fun. I have no regrets. Big smiles after driving hard on the snakey sections of the Great Ocean Road making shifts with the paddles.
I am sure I would still love the car if it was a manual.
Off topic - I was taught to drive with hands at 10 to 2 position on wheel. Interesting that at the VW drive day one of the pro's focussed on seating position in the car. Seat should be low (tick), steering wheel fairly high (usually I would go as low as possible and still see the dials), hands should be at quarter to 3 to allow you to make most turns without having to shuffle your hands on the wheel. Last tip made sense and so I have made the change, which took a while after decades of driving at 10 to 2.
The hand position recommended is ideal for paddle shifting as the paddles are right where you need them when it is time for a shift.
