A Bunch Of Merged "My New Car / Order" Threads
This topic is closed.
  • Originally posted by Stoney! View Post
    *MFD speed is 3 or 4 k's under speedo speed, so cruise control takes the speedo to say, 84 when set to 80...
    Stoney!
    This is deliberate and on many different cars not just VW. Can't tell you how many times I have been glad of it after not seeing a speed camera!
    MY2014 Skoda Octavia Ambition Plus Wagon, DSG, Capuccino, Tech Pack
    MY 2010 Skoda Scout Manual Silver -traded
      It's the RNS 510 I'm most worried about though, it shouldn't be shutting down like that, and being an intermittent thing I'm worried it may be hard to resolve.
      IIRC there was mention recently somewhere on this forum of a "dead spot" on the F3 between Sydney and Newcastle - that might be what has thrown your RNS510.
      • Originally posted by gregozedobe View Post
        Very interesting thanks for that, makes a little sense actually cause when it did come back on it plotted me somewhere out in the ocean lol.... thought it was part of the fault
        As far as the MFD FAULT goes, I don't like it, cause when I set cruise to 100 on MFD, the speedo dial sits on 103, so thats hardly saving me from speed cameras i don't see...
        But beyond the faults, I adore this vehicle, its started to open up now with 700k's on the clock. Performance is awesome, I also noted they perform much better (even just in gear acceleration) with the TCS switched off, turbo and supercharger are a lot louder also.
        Handling is fantastic, on the trip to Newecastle i recorded 6.3/100k's with only 100 odd k's on the clock which i thought was great for such a tight engine, I'm averaging around the 7 - 7.5 mark back in Sydney, which im extremely happy with.... I filled up the tank with 1/4 left in it tonight with 650 k's on the trip meter from full. So prob could have got around 800 out of it.
        Stoney!
        6 Sp Manual 118 TSi
        Colour: United Grey
        Build Date: August 09 Delivery Date: 16th Oct 09
        ODO at last fill: 2555km
        Avg Fuel Cons at last fill: 8.6
        • I checked out the mirror lights in my 118TSI. They turn off if you flip the visor up, even if the mirror is uncovered so if yours are staying on someting odd is happening. Wonder how hard it it to take the bulbs out?
          Not that you should have to do anything.
          2009 118 TSI
          1980 Bedford van
          2015 Hyundai i30 SR
          • My speedo needle? sits slightly above the MFD speed, I thought it was the divergence as the dial is slightly to the right and I'm just looking through the angle. Its about 2-3k's past 100 when cruise control is on 100.
            The vanity light is a worry, does it shut off with the ignition off?
            My RNS510 also had some issues early on with booting up and rebooting randomly. I did the firmware update and its seems solid now. I had an issue with the RVC coming on then going blank which I put down to the slow boot up of the HD.
            Good luck with the dealer, this is where VW needs to follow through with great after sales service and problem solving.
            2018 Skoda Superb TDI
            2010 Skoda Superb TDI
            2009 Golf VI 118 TSI
            2006 Multivan TDI SOLD
            • Thankfully, yes the light goes off once the car is locked. I made sure to check that, worrying it would flatten the battery.
              I have however found TWO MORE PROBLEMS with this car now... the bonnet is a few mill's higer than the guard on the passengers side, and the reset button, normally found next to the ESP button, for the Tyre pressure monitoring system isn't actually there??? I mean what the hell.... this is looking worse and worse, I'm starting to become rather disatsfied with the over all QA of this vehicle.... A car I've been wanting to buy for many years, it's a let down you know.
              My RNS510 also won't play any DVD's I put in, sayion the DVD has the wrong region code, Also spits out SD cards saying it has an error. Becoming a little over it.
              Stoney!
              6 Sp Manual 118 TSi
              Colour: United Grey
              • Sorry to hear about this Stoney. Reset button for tyre monitoring is in the glovebox in the upper r/h corner.
                Hope it improves
                GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
                • Originally posted by Ozram View Post
                  Yeah it sounds like poor old Stoney is getting a rough trot here. I take it you were able to fix the rear window problem though by resetting it.
                  Ozram, has the reset button been moved in the latest shipment as I too thought the Mk6 should have it in the console? Reason I ask is I am vaguely interested in retrofitting it to my non sports pack car.
                  Golf Mk6 118 TSI DSG |APR Stage I ECU Upgrade | HEX-USB+CAN
                  • Het Logger,
                    Dunno when it changed but mine was built in June and has the button in the glovebox. It works too - when I changed my wheels in the first few days I was driving back from the tyre shop and the light came on. A stop and quick inspection deemed nothing wrong and then after pressing the button so the system could re-learn, the light went out and has not been on since.
                    Also, not sure if a retrofit is possible. I think it uses the wheel sensors for the ABS though.
                      Stoney!
                      So, basically you have three problems?
                      Speedo vs MFD
                      Issues with stereo
                      Vanity mirror lights.
                        Het Logger,
                        Thnx for pointing this out. Might be something to do with build run. BTW, There is a retrofit kit for the MK5 but not the MK6. It comprises the missing wiring harness and the OEM button. But I also spoke with developers of this kit in Germany and they said that due the MK6 ABS controller differences there would not be a suitable harness available any time soon. This is further exacerbated the coding for the New ABS controller not being widely available yet.
                        • Vanity mirror light
                          Bonnet fit and finish
                          DVD set to wrong region code
                          RNS 510 Switched off a few times yet to do it again.
                          Rear, offside window stopped working - yet to do it again (didn't touch anything to do with that-just started working)
                          TPS switch not in console and nothing in manual telling me its in the glove box, but will take a look in there now.
                          More than enough to be pissed off, on top of that I asked for the MDI to be dealer fitted in the glove box so it didn't chew up my Centre console, but they factory fitted it anyway, and they put the wrong sill plates on. Bill Buckle were great in the beginning, But i'll wait to see how they go with after sales service.
                          Stoney!
                          6 Sp Manual 118 TSi
                          Colour: United Grey
                          • If its any consulation Stoney! Buckles just honoured a warranty repair on my Subaru 18 months out of warranty... mostly becasue it was their responsibility, but they could have been pr1cks and not done it.
                            Sure your car wasn't wired up in Italy? There's a large number of electrical gremlins in your list.
                              Het Logger,
                              A retrofit is possible.
                              website: www.my-gti.com
                                Vanity mirror light
                                Stoney!
                                That really does suck. I had one extremely minor post delivery door trim issue that I could have fixed my self anyway. You have been unlucky having so many. Lets hope the dealer get you sorted ASAP.
