MK6 Wheel / Rim / Tyre Thread
  • To be honest it sounds like a massive waste of money.
    Why would you upgrade to a 1" bigger version of the wheels you already have and they're only rep's?
    Plus the cost of a set of new tyres as well.
    • There's often 19" original Talladegas coming up for sale so I'd just keep an eye on the parts for sale listing. Why buy knock-offs when you can buy the real thing (second hand) for not much more.
      - Tigger73's 125TSI Build
      • reps add weight. As for anything else, the tyre should become smaller to keep the rolling distance the same. Personally I'd want better stance (lower offset).
        You can easily make the ride more harsh, added weight and cheap tyres don't help.
        IMO do it right, get some nice looking rims, nice tyres, consider the offset, tyre width, impact on handling and fuel economy. Tyres are your only link between power / braking and the road, going cheap will be a step backwards on a car that is performance oriented.
        • Originally posted by spfh84 View Post
          anyone know if there will be a problem with rubbing at full lock, I'm almost certain they reduce the throw of the steering rack on OEM cars with 19's
          if the wheel and tyre width are the same, offset is the same, and rolling diameter of the new tyre is the same as existing there will be no change in clearance
          Bora gone
          Vento VR6
          MKIV GSW TDI
          7P Touareg TDI
            I think they're might be something in that comment. My Golf R was supplied on factory 19's and it has an awful turning circle.Another mate with the same car and spec's thinks the same.
            Maybe the extra width and diameter made VW reduce the lock?
            Lewis
            2010 Golf R 5 dr , Black , DSG , Leather and 8.5x19 ET50 AZEV Type R
            • Thanks for the replies, reason for the change is he wants black wheels, and wanted them OEM but as it was a run out model there were none available in the colour he wanted and the dealer was reluctant to swap which brings me on to the steering lock, my r has factory black 19" wheels and is like a ship to turnaround...we were thinking maybe that's why the dealer wouldn't just swap the wheels over, there must be a factory mod. Just putting the feelers out there as to quality of the knock off rims. If you wrap knock off wheels in good tyres, except for weight which I'm sure isn't massively different, surely there's not much difference from OEM...or am I missing something?
              • Upgrading 18&quot; for 19&quot;
                Yep, the steering racks are different for the 19". If you put the 19" on there will be some rubbing. Dealers are aware of the problems and would not be prepared for change due to possible warranty issues.
                  Why doesn't he just get the wheels painted.
                  There is a significant weight difference between rep's and real.
                  I had 19" reps which were 12.5kg per corner, then i upgraded to my enkei's and they are 8kg.
                  So 4.5kg per corner and it's unsprung weight which makes a huge difference.
                  • What are the duck's nuts at the moment with regards to tyres? I'm due for a new set. Ive got Conti CSC3's at the moment, they're alright but just thinking of trying something new like some Michelin or Pirellis. Mainly after a good all rounder - something good for general everyday use with reasonable wear, but also at home on the twisties & occasional leisurely squirt around the track. Cheers
                    • Originally posted by Tobes_WIR35 View Post
                      Goodyear Eagle F1 Asymmetric 2 | the Goodyear Eagle F1 Asymmetric 2 reviewed and rated | the online tyre guide
                      look no further
                      MINI Cooper S Clubman - FWD
                        Michelin Pilot Super Sports, unbelievably good grip and wear (so far). Not too noisy when cruising, very impressed with these tyres, I would say the best I've ever had.
                        Forever blowing bubbles.
                        • Originally posted by Pullstarter View Post
                          They certainly should be the ducks guts - if you can find a set
                          Local tyre shops tried to tell me they would be $450 each but could not obtain them
                          So I imported two, $320 each including freight, have not fitted them as yet
                          I'm currently using Michelin PS3 and Goodyear F1 A2
                          Both are high performance tyres and both are wearing well (slowly)
                          I have a preference towards the Goodyear F1A2 for enthusiastic driving
                          The Michelin PS3 have a little less road noise
                          I bought the Goodyear F1A2 from Tempe Tyres for $240 each - absolute bargain!
                          I have used the Conti CS3 on numerous cars
                          They do last well and do have a pretty good level of road holding
                          Not great but not bad in the wet
                          They crash and thump through pot holes - uncomfortable
                          • Originally posted by Martin View Post
                            that's because Michelin Australia does not bring in the PSS in 225 40 18. They only officially bring in the PS3. Any Aust tyre shops that sell PSS in 225 40 18 are likely to have imported them directly from somewhere.
                            the F1A3 is probably the only option out of the 2 cream of the crop tyres at the moment for those with cars on lease where service & maintenance costs (incl tyres which must be bought locally?) are included in the package.
                            Goodyear does 4 for 3 occasionally, which brought the set down to $1200-$1300 fitted for 225 40 18 last time I checked. BUT, Tempe Tyres does sell the F1A2 in 225 40 18 for only $250 ea in eBay, + interstate courier $70 + fitting & balancing ($60-$100 in Brisbane), dunno if lease package can accept this kind of purchase.
                            • You can get the Michelin PSSs for about $1300 shipped from Tirerack.
                              • Re: MK6 Wheel / Rim / Tyre Thread
                                Wanted to try something a little different to the usual suspects, had a set of Hankook Ventus S1 Evo2 fitted and balanced at Jax's for $900. Size 225/40/18.
                                Grip, so far, in dry and wet conditions is impressive and time will tell how well they wear.
                                Tyres are significantly quieter than the Bridgestone Potenzas I had on previously.
                                Sent from my GT-N7105 using Tapatalk 4
                                Golf R Mk7.5 2020 MY20 | Indium Grey | Sunroof | Dynaudio Excite 400W Option
