I have today replaced the front rotors and pads with Bendix Euro+
and now I have noticed that the brake pad sensor is incorrect.
The solution was to cut it and solder the new 1/2 one to the new old one
the only problem now is that the brake pad warning light up on the dash
No fault codes on the OBD2 scanner or on the mechanic scanner
I need to know the resistance value thats needed to cancel this warning on the dash
or if I can VagCom it or use the OBD2
Its annoying as it comes up every time I start the car
cheers
cheers
